CPP Under Floor Booster/Master - Built In Residual Valves?
I'm trying to plan out my brake system and have a quick question regarding Residual Valves.
I have a '56 F100 with front disc brake conversion and drums in the rear. I have the CPP under floor booster/master kit.
I have emailed CPP to ask if this master cylinder has residual valves in it and will update if they respond.
These look sort of like what I'm seeing on the internet regarding residual valves in the master cylinder, but I can easily slide a paper clip all the way in, which leads me to believe they are not residual valves (if everything you read on the internet is true!). Any other ideas on how to "test." Or does anyone remember what they did for their truck using the same setup? Luckily, adding in line valves is easy enough..I just want to be sure!
Thanks!
Also, a lot of the tech articles from CPP and around the net show a different bracket than mine. I guess they changed the design? I got mine this year directly from CPP. Mine only uses the 2 original bolt location and doesn't have any "supports" or additional holes that need to be drilled. I guess maybe they beefed up the bracket...still seems like a lot of weight on those bolts!
Thanks!
Good advice from AXracer as usual....
Tech guy said that they are not built into the master cylinder...so looks like external is the way to go.
I ordered the Wilwood ones off amazon: $21.65 with free shipping.
and I went ahead and ordered the "kit" from CPP for the brake switch (even though last time I just rigged it with parts from Oreilly Auto Parts and it worked fine). But it's only $21 shipped as well. These days, money is more abundant than time.
Hydraulic Brake Light Switch
Now I just need to figure out if I want to go remote reservoir and, if so, what remote reservoir cap I want to use....
It is sad that we can't trust the guy on the tech line...I don't think the residual valves are ever in the prop valve? I Think he's correct that they aren't in the master cylinder, as there don't seem to be any valves behind the fitting in the picture.
If that is your picture...........
The valves are in the bottom brass piece.
well not brass....... but yellow zinc coated plate.
http://www.classicperform.com/Store/...ck/4852BBD.htm
Says there that they are included, and not needed if drum/drum.
If that is your picture........... The valves are in the bottom brass piece. well not brass....... but yellow zinc coated plate. http://www.classicperform.com/Store/...ck/4852BBD.htm Says there that they are included, and not needed if drum/drum.
I don't see any mention of residual valves in that cpp link you provided? Just the proportioning valve which I am going to need (I'm doing a disc/drum).
Thanks again for helping me try to figure it out!
Maybe I should call back in for a 3rd opinion! Ha
I guess the only sure way is to take a look...
The tech guy I spoke with said "No they aren't built in. The only reason you'd need them is if your master cylinder is below your wheels cylinders or calipers. We sell the residual valves too if you need them."
Thanks for the input!
The do I or do I not need residual valve question has nothing to do with whether you are using discs or drums. They are only required IF your master cylinder is below the level of your calipers/drum cylinders to prevent fluid draining back to the master cylinder under gravity. However, depending on if you are using discs OR drums, will determine which residual valves you will need IF they are required. ie 2lb for discs and 10lb for drums. I suspect some people MAY be confusing the role of the proportioning valve and the residual valve.
Well dang...
