Using Dry Ice for dent repair???
Old 10-26-2014, 09:45 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
I know that just because something is on the net doesn't make it true, so I figured Id ask you guys. I was researching ways to remove shallow dents on older cars and trucks, like ours without damaging the paint. I ran across a method using dry ice . It said to place the dry ice in the center of the dent claiming shrinking in this way will cause the dent to pop back. Ive heard of using a torch starting at the outside of a dent circling slowly towards the center to accomplish this, but never dry ice. Has any body ever heard of this one way or the other? I have had some success using the hot glue pad stud method, but Im always looking for other ways of paintless repair.
Old 10-27-2014, 08:22 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Would like to know if this works as well. Wonder if those "Dent Dr." (Paintless dent removal) places use it?
Old 10-27-2014, 08:36 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
I've never tried it, but have been told it works on shallow dents. It is used mostly on newer cars I think, so I don't know how well it would work on our trucks with much thicker and better steel.
Old 10-27-2014, 10:13 AM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
Old 10-27-2014, 02:41 PM
underthebridgejim
FTE fan
Thanks for the input guys, Im always trying to learn, but it's not true unless you guys say it is.
Old 10-27-2014, 05:41 PM
rhopper's Avatar
rhopper
rhopper is offline
I've heard it works if you park the car in the sun to get it hot first. I don't think it would work on the thicker metal on our trucks.
Old 10-27-2014, 05:54 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
I've used the dry ice to remove hail dents - The large pieces of dry ice will cover multiple dents - I've also used a wet rag soaked in ice water shllow dents - After The dents is fixed I usually go thru the heat/cool cycle to make sure the metal is happy
Both ways work better the longer you let it set in the sun or use heat lamps
I've used a torch to heat the metal - It's not very friendly to paint
The metal in new cars is harder and thinner than current day cars - It takes more cycles to complete
My Dad showed me how to do it when I was working on my 40 Pontiac = I've also used it on mid 50's Fords and the other ones
Fat Fendered Ford
13
12-12-2008 08:26 PM
dixiemudder04
Paint & Bodywork
05-01-2007 03:02 PM
wvmudder
Paint & Bodywork
13
06-02-2005 08:34 AM
Rcmgiasson
Paint & Bodywork
12-03-2002 12:40 PM
TCTOOL
Paint & Bodywork
03-26-2002 09:13 PM
Quick Reply: Using Dry Ice for dent repair???
