1964 transmission swap
There are a lot of options when it comes to transmissions. Sometimes it is best to decide on what you want, granny gear, overdrive, etc. and then define the transmission based on those parameters.
A granny gear trans from a '64, and its appropriate bell are an option.
The '64 truck uses the bell housing for the rear mounts. Its pretty doubtful you will find a modern trans that will fit your bell housing, without modifying your bell or trans or both.
Several members here have used a modified 3 speed bell (like yours) from John Mummert to install a T-5 trans behind Y-blocks.
Try the search option here for additional information.
Good luck.
Good luck.
BogginWagon
04-29-2014 08:59 PM
jacks61ford
24
08-03-2012 07:21 PM
moore1960
10-31-2002 08:12 AM
