Crown Vic front end
I haven't yet.. But am trying to gather as much info as I can about this swap. Looks pretty staraight forward and easy for the most part. However any tips or info surely would come in handy. I have seen a good write up about doing it on a 1972 f100 over on Fordifcation.com website, but not sure if 72 and 80-86 frames are the same.
The simplicity and durability of the Twin I-Beam can not easily be beat. They drive fairly well for a truck front end, and ride fairly well. I don't know why someone would want to make it very expensive and complicated just for a little bit better driving feel. Personally, I really like the Kingpin Twin I-Beam setup that I have.
Benefits would be;
Ride height can be adjusted to suit.
rack and pinion steering.
Smaller wheel pattern for more selection in wheel designs.
They are just going down a different path with their trucks, building them to suit their needs.
Some people want to change their trucks personalities, making them more street rods that working trucks. The biggest problem with the twin-i-beam suspension is ride height. You can't change it without serious modifications or expensive drop beams. People are looking for solutions to this, changing the complete suspensions on earlier cars and trucks is done all the time. People are wondering if this would work also on these trucks.
Benefits would be;
Benefits would be;
Yeah, there's a real simple solution to changing the ride height of a Twin I beam front end. Solid axle. Personally. I have never driven a modern vehicle with a complicated steering system that I liked the feel of. I've always much preferred the old simple steering systems for the way they drive. I'm just weird I guess.
It's all about a nice ride too. Straight front axles are for heavy duty trucks that haul loads. When that heavy straight axle flops up and down after hitting a bump, you know it all the way up your spine till your teeth rattle. The crown vic frontend will have a nice smooth ride, especially if aluminum rims and reasonable sized tires are used. The whole thing is aluminum(or most of it). It would be a good upgrade for a 2wd street truck if it would fit without too much trouble.
steven97439
07-30-2012 08:47 PM
OldSkewl 79
09-11-2010 12:16 AM
Backroads_Jack
01-01-2009 12:55 PM
codys50ford
17
01-14-2008 09:36 PM
moonlightdriver
13
07-04-2007 06:08 PM
