Crud in Air Intake
I have sprayed carb cleaner into the throttle plate for many a year. I do it every six months. Keeps it running great. Now I read more often, should be using Fuel Injector Cleaner....there's supposedly a coating on the throttle plate that carb cleaner eats away at. Who knows?
Use "Throttle Body" spray cleaner not Carburetor cleaner. The former won't hurt the Teflon coating on the bore/blades. Fuel injector cleaner is typically meant to run through the fuel system to clean the inside and tips of the injectors - you don't want to pour it in the throttle body.
I vaguely remember reading the teflon coating in TB did not start until some time after '86? If you have it there's a sticker saying so underhood somewhere? If this TB had a any type of coating, it's gone.
I don't know about spray carb cleaner vs injector fuel treatment other than I have Seafoam in the tank which didn't appear to have any effect. But when I sprayed carb cleaner, the idle jumped to over 2000RPMs from 1200-ish and stayed there. (The previous owner replaced the idle set screw with a longer screw and used it as an idle adjustment.)
I found the reference regarding the Teflon coating:
"Beginning in 1991, Ford began using a Sludge Tolerant Throttle Body design which includes a special slick Teflon coating inside the throttle bore ... The issue is harsh cleaning can remove the sensitive Teflon coating eliminating the protective qualities. These Throttle Bodies can be identified by a black/yellow sticker on the Throttle Body warning against cleaning or adjusting..."
Sorry, it's off-site, but that's where I remember reading about it.
No problem it's from FSB, there's some decent stuff there....
This is what I have heard(but can't back it up). The teflon coating was one of those "better ideas" from Ford that never did work, and you can go ahead and use something that eats the coating off, because it's going to get dirty anyway, just like the old ones did, and you can then clean it like the old ones, every so often.
