Ford 332 v8 transmission
Old 10-20-2014, 05:08 PM
fordtruckguy98's Avatar
fordtruckguy98
fordtruckguy98 is offline
Smile Ford 332 v8 transmission
I was wondering what transmissions could i put in my truck. Its a 1963 ford f350 dump truck with a 332 V8 2wd. i heard i might be able to put a zf5 transmission. but i don't know if it will bolt up. i don't know whats in it. it has a 4 speed in it now. any help would be great thanks.
Old 10-20-2014, 10:26 PM
garbz2's Avatar
garbz2
garbz2 is offline
The only trans missions that will bolt to your bell is a pre 64 four speed or five speed truck trans.
You can have the Big Ys 302/332 bell sent out to be machined and adapted to a NV2500 or later NP or even a T19 but expect to shell out at lead 2500 to 3000 for the conversion
List the trans that is on your door plate.
Garbz
Old 10-21-2014, 10:03 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
332 (and 302) are Lincoln derived Y blocks, were only installed in 1956/63 F700/950's. Only V8 available for 1961/64 F350's was the 292 2V.
Old 10-21-2014, 05:01 PM
fordtruckguy98
The motor isn't orginal to the truck its out of the 70's or maybe the 80's is what the owner told me that put it in the truck. He fooled me it looks stock in there.
Old 10-21-2014, 05:27 PM
TA455HO's Avatar
TA455HO
TA455HO is online now
Color me confused. The 332 Lincoln was last made in 1963 and that's what is in your truck? But the engine is from the 70's or maybe 80's? I'm not able to connect the dots.
Old 10-21-2014, 07:19 PM
fordtruckguy98
I was told that it was a industrial engine that was in the bigger trucks. I was also told that it has sodium valves or something like that. I'm just as comfused as you are.
Old 10-22-2014, 03:33 AM
NumberDummy
How many valve cover bolts per side does it have?
Old 10-22-2014, 10:19 AM
fordtruckguy98
There are 5 bolts that bolt the valve covers on and the valve covers also bolt to the intake. The motor is stock and it has red paint. I was told that the motor was from a big truck like a f600 and the motor was a industrial engine with sodium filled valves. Would a picture of the motor help at all?
Old 10-22-2014, 04:00 PM
NumberDummy
Don't need to see a pic.
It's an FT engine, these were installed in 1964 thru 1978 500 series and larger trucks, with one exception.
There are 4 different FT's: 330 2V Medium Duty - 330 2V Heavy Duty - 361 2V or 4V (1974/78) - 391 4V
1973/78 F350's made exclusively for U-Haul came with the 330 2V M/D
Old 10-22-2014, 06:32 PM
fordtruckguy98
After further research I have found that it is a ford 330. Does any one have any specs on this motor. Is it any good? What years was it made? What size trucks did they come in? What transmissions will bolt up to it? Any information would be great thanks!
Joelav
10-31-2018 02:01 PM
HkyswiM
09-28-2011 11:53 PM
Shortys
02-02-2010 11:51 AM
mad scientist:p
04-24-2007 11:23 PM
fordbeast_80
02-27-2006 12:04 AM
Quick Reply: Ford 332 v8 transmission
