Code P0607 - Across the Pond
Hi bubbasz1,
Yes that's our truck at the far left of picture parked next to my buddies King Ranch. He ribs me about my black exhaust tips at 25,000 miles - he has over 80,000 with clean pipes but he drives everywhere at full throttle.
Here's a better picture of us waiting for the ferry to Holland this year.
John
John
Hi bubbasz1,
John
John
NEXUS 4. IB AutoGroup
Hi SANDDEMON08,
We bought the truck very early in 2007 from Gator Ford, Florida. The truck has been stock from day one. A few months into ownership I noticed the tailpipes black - have cleaned them up a few times but they always come black again. Our compulsory yearly Transport Department vehicle test shows virtually zero emissions. So, just going to live with it.
Some time ago there was a thread on FTE where a guy walked round a parking lot looking at Super Duty tailpipes and he reported seeing over half the trucks he looked at had black tailpipes.
Unfortunately when anything goes wrong with our trucks over here we are on our own and have to fix them ourselves. No warranty outside of North America, therefore, FTE is a lifeline.
I even had to import a new set of tyres from America. Cannot get tyres for 18" rims in the UK.
John
John
Hi bubbasz1,
This is a mile off topic but what the hell, I have to respond - it's good to talk.
The UK has always had a fair number of full size trucks owned by enthusiasts.
A lot are left here by servicemen when they return home from your bases in the UK and others are imported.
The majority of imports are 1500 Dodges cause they work out cheaper than other makes.
Americana in general is big in the UK with various big shows of trucks, cars, music, motorcycles, etc.
My interest in all things American started in the 50's when my Dad used to buy me "Popular Mechanics", so I was brought up with :
La France Fire Engines
Cris Craft
Cessna airplanes
Alco locomotives
70's sedans (my favourite)
and how I would love to hold a finely engraved 357.
Narrow British roads are a myth - yes, we have narrow backroads as you but we have some good major highways, a bit overcrowded but we are a small country.
John
Cris Craft
Cessna airplanes
Alco locomotives
John
Hi bubbasz1,
Cris Craft
Cessna airplanes
Alco locomotives
John
Cris Craft
Cessna airplanes
Alco locomotives
John
If you ever get back over to the US drop by Michigan and you can shoot my 686(stainless 357) just not engraved.
Keep in touch, PM me any time you feel the need.
Jeff
PS, I loved popular mechanics magazine from the old days, good stuff.
No 70 sedans though, I have a couple 65"s.
Update :
I fitted two new ACDelco 65PG batteries (couldn't find supplier of Motorcraft Group 65 in the UK) last night but didn't run the truck cause we had the tail end of hurricane Gonzalo that you sent over.
Fired her up this morning. No check engine light and no codes. Test run for half an hour - stop/start and still no light or codes.
Thank you all very much for your help - much appreciated.
John
John
Update :
John
John
Hi again,
After clearing the check engine light and P0607 by fitting new batteries, a few days on and I've got the light back and code P0607.
Out of five starts on a 125 mile trip last Sunday, the light and code came on three times.
Any ideas what I can check now? Would it be worth trying to find a service station that can perform a diagnostic check?
Incidentally, the truck runs great.
Any help would be appreciated.
John
John
Hi again,
John
John
Did you happen to check the battery voltage again. If the battery's are going down then there could be an issue with the charging system that would need to be checked. Outside that you may need to take it to a dealer , unless the shop you are thinking about has the proper ford IDS And vcm to preform a proper diagnostics.
Hi SANDDEMON08,
Thank you for coming back.
Although the batteries were low on voltage 12.56 when delivered they soon charged up last Sunday with a good run and have since maintained a very healthy voltage while sitting. I am monitoring them closely.
I have checked the through connector that you mentioned in an earlier post. It appears sound and clipped securely. Although I haven't checked the connections to the PCM - not sure where it is inside the truck.
I have found a Ford dealer (80 miles away) that has the very latest integrated diagnostic system. We are scheduled to travel to a campground nearby and will be taking the truck in next week.
I asked if it was safe to drive the truck 80 miles. His reply was "if the check engine light is steady (minor fault) it's safe to drive and if the check engine light is flashing (serious fault) don't drive the truck". Does this sound correct to you?
John
John
Yes if the light CEL is flashing you shouldn't drive it tell it is checked out, steady you should be fine at get it checked out asap.
#28
Update.
Took the truck into Ford dealership today. Results of diagnostic check :
U137-60-PCM (Lost communication with trailer brake controller module)
P0607-FF-TCM (Control Module Performance).
No faults found. Advise - overnight charge of both batteries and the check engine light will go off in time.
I am aware of the trailer brake controller issue cause I have unplugged the Ford in-cab controller and plugged in a Tekonsha P3 which is compatible with our electrical over hydraulic brakes on our travel trailer.
Regarding the P0607 code they said that they come across the check engine light quite often after a battery disconnect or depleted batteries. I cannot say that I am happy with the outcome cause the check engine light is still on, so will probably seek out an independent for a second opinion/test.
John
John
#29
Latest update.
After returning to our home town, took the truck to a local independent repair shop. After the usual diagnostic tests and a reflash, both failed to clear the code. A PCM was ordered - waiting weeks for this to arrive, it also failed to clear the CEL.
A new transmission control module was ordered and took five weeks to arrive in the UK, then got lost!! After receiving a refund, the repair shop ordered a second TCM. When this was fitted it extinguished the CEL and, after road tests and numerous ignition cycles, all is fine.
Relieved to close the gate on this one - it's been a long haul.
Thanks to all who posted on this thread.
John in the UK
John in the UK
#30
Thank you John for completing your post.
I have the same P0607 code on a 2008 w/ 6.4L Powerstroke but the issue is more serious, probably progressed further.
I have noticed the Transmission Range Indicator (PRND321) intermittently flashing and sometimes out completely. (The rest of the instrument cluster is stable)
When its out, the truck shuts off, like I turned the key to accessory.
I have the P0607 every time the light flickers (and truck misfires)
I have had the U0101 (lost communication with TCM) a couple of times.
I have chased grounds, cleaned all related connections and monitored my voltage.
Eachj time I cleaned a major connector or added a ground it seemed better, only to come back again shortly.
I am about to remove my TCM again and send it to a refurbisher.
But first I wanted to ask if your Transmission Range Indicator (PRND321) had been flickering or out during your difficulties.
PS: Your connections to your PCM are on the firewall directly behind your air filter box
cutlass
09-12-2010 07:13 PM
