What to do with virgin 01? Look Tugly
Old 01-18-2015, 02:49 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Originally Posted by crop harvester
If you service your coolant properly from new,you may not benefit much,International Harvester installed them on the T444E,I have noticed most diesels in larger equipment has coolant filters
Yes they do. I think part of the reason they install those filters is to provide sca additive to the coolant over time to keep the ph level right.
  #152
Old 01-18-2015, 05:55 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
I was told the truck got 16.2mpg on a tank of fuel!
  #153
Old 01-18-2015, 07:39 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Snow, if yours is a handshaker, than your nottoo far off from me. Think im around 17.5-18mpg. Seen 20 before but notsurehowthat happened. maybe downhill from vegas
  #154
Old 01-19-2015, 09:30 AM
Snowseeker's Avatar
Snowseeker
This is an auto Tim. Being a 2wd regular cab I expect to see at least 17+ all the time out of this thing. In summer I want to see 19-20 every time the truck leaves the yard.
I'm gonna make it get it and its gonna like it.
  #155
Old 01-20-2015, 09:42 AM
Tailgate77478's Avatar
Tailgate77478
Tailgate77478 is offline
You might be able to get there...but don't bet on it due to your heavy load in the long back. Also, you have tow mirrors (-0.5 mpg), big AT tires (-1 to -1.5 mpg), your lift (up to -2 mpg) etc. Have you recalibrated your speedo to the larger tires? I know 285's are about 4% farther distance, so that can screw up your calculation and your actual mileage may be 4% better...or approx +0.5 mpg.
  #156
Old 01-20-2015, 07:52 PM
Snowseeker's Avatar
Snowseeker
Stock size tires? and I believe they are HT would have to look again. Lift?
I have pretty much all the motor maintenance and stuff to go threw yet before I can really see what we are going to be getting. I know the up pipes have leaks in them, I can't tell how bad, doesn't look to bad but I can only see a little bit around the pipes. Possibly boost leaks yet too, I also haven't checked that yet. Lots of things to get into yet.
  #157
Old 01-22-2015, 12:27 PM
brian42's Avatar
brian42
brian42 is offline
Sorry for the late response but if the OP didn't get these answered:
One other thing weird about this truck. It is originally a cali truck but I see no cat under it and all else looks normal. What (if any) extra emissions were on cali trucks in 01?
Originally Posted by Tugly
Cali truck will have a GPCM instead of the GPR, and maybe different tuning. Some had cats, but most didn't... and I don't know why or when.
A CA 7.3L with an automatic transmission did not come with a cat (some of the early ones of this generation might have gotten one in the 99-00 range). There should be an emissions sticker under the hood that says 'catalyst not required'.
My 285s put my speedo as close to dead on as I can get (according to my Garmin GPS). The 265s had my speedo a little high (by about 2-3mph at freeway speeds).
  #158
Old 01-22-2015, 07:39 PM
Snowseeker's Avatar
Snowseeker
Trucks are supposed to have 265's stock? Sorry I have not looked at the door tag at all in this truck yet.
My excursion has 285's stock, I just thought the was what was on superduties 00-03.
I keep meaning to take the garmin along to check the speed because I question the tach. In my X 70mph is dead on 2000rpm maybe pushing 2050. In this truck for some reason 70mph reads 2200ish rpm's. I know when you start going over 2000rpms the mileage drops off quick.
  #159
Old 01-22-2015, 07:48 PM
brian42's Avatar
brian42
brian42 is offline
They came stock with 245s or 265s depending on the package. Mine came with 265s.
  #160
Old 01-23-2015, 06:29 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
My 02 X came with 265 stock and will probably go with 285 next time around.
  #161
Old 01-23-2015, 06:43 AM
Tugly's Avatar
Tugly
Tugly is offline
I tried going with door-sticker-sized wheels, but Stinky would twerk when passing, so those came off the next day. They also made Stinky look like one of those Tootsie Pop women at Wal*Mart.
Important note: The air pressure on the door is for those skinny stock tires. When changing tire size, you need to refer to the manufacturer's inflation guide, not the door. I estimate our noses are between 4000 and 4500 pounds with a driver, passenger, and an empty bed - so properly airing the front tires need a little homework.
  #162
Old 01-23-2015, 07:17 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
So are you saying to go by what's on the side of the tire for air pressure? I've heard different ways but not sure which is the right one to go by.
  #163
Old 01-23-2015, 07:36 AM
Snowseeker's Avatar
Snowseeker
Our work trucks all get 80psi all around all the time.
I will for sure have to check the door tag and the actual tire size and then check the speed. That is a great starting point for the mileage, actually making sure the mileage is correct yah? lol
  #164
Old 01-23-2015, 08:31 AM
brian42's Avatar
brian42
brian42 is offline
My truck's front end weighs 4400lbs (full tank, empty bed and nobody in the cab).
Toyo has a .pdf that explains more than you ever wanted to know about tires and load capabilities. There's an equation to extrapolate your tire's load capabilities at any pressure. There's also a chart towards the bottom that does most of that for you for just about any type and size of tire.
This is what I use when I'm not loaded or towing so I don't always have 80psi in the tires and wear down the center rib section of my tires prematurely (I only get 35-40K out of my mud tires if I take really good care of them):
http://toyotires.com/sites/default/f...-LT_102913.pdf
  #165
Old 01-23-2015, 08:49 AM
Tugly's Avatar
Tugly
Tugly is offline
Like brian42 says, use the guide from your tire manufacturer - or use some of the tread-wear tricks found on the forum. I know from experience that going less than 65 psi in the front with my tires on Stinky is like driving on a cheese grater.
Originally Posted by brian42
My truck's front end weighs 4400lbs (full tank, empty bed and nobody in the cab)....
I feel reassured that my estimate was so close. There will be a significant difference between 2WD and 4WD, though.
Quick Reply: What to do with virgin 01? Look Tugly
