Try cleaning your tb and clean or replace iac valve. This should help smooth your idle. Also check the timing and fuel pressure, wouldn't hurt to do a compression check either.
Fuel pressure is good , wires cap all good , fresh tune up. Timing is good as well as compression and injectors. I'll clean tb over weekend and check the iac. Thx.
