Bondo Differences?
Bondo Differences?
Need to do a little filler work on some panels of a 1995 F150. Which product would be the best suited for filling some minor dents and dings?
Regular Bondo
Bondo Professional - states works better with galvanized body panels used on 1998 and later vehicles
Bondo Fiberglass Reinforced - states stronger than regular bondo
Thanks the help!
Regular Bondo
Thanks the help!
Try 3M Marson Platinum Plus Premium Gold Lightweight Filler - 01131.... I use to use rage but switch to 3M because i found the consistence to be the same as rage xtreme and depending what paint store you go to will be 10 to 20 dollars cheaper than rage....if your on a budget use evercoats lite weight filler it under 20 bucks for .8 gal.
Aaron-71
22
08-19-2010 01:35 PM
