1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
02 F250 swaying back and forth
Old 10-06-2014, 04:48 PM
dougcepress's Avatar
dougcepress
dougcepress is offline
I have a 02 F250 V10. When I am pulling a trailer and began to travel over 50 MPH the truck feels like its moving left to right almost like its sliding on ice. Its worse the more weight I am pulling. When I am not pulling anything there is no issues. The trailers I am pulling are gooseneck trailers. What would cause this.
Old 10-06-2014, 04:55 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
What would cause swaying? A few possibilities.
1) Under inflated tires
2) Worn out tires.
3) Worn out shocks
4) Loose steering components, tie rod ends, ball joints, etc. Needing an alignment.
Old 10-07-2014, 07:01 AM
rjcorazza's Avatar
rjcorazza
rjcorazza is offline
Consider checking pin weight. Adjust pin weight to 20% of the actual trailer weight.
DontUluvFod's Avatar
DontUluvFod
DontUluvFod is offline
Sway bars and weight distributing hitch?
Old 10-07-2014, 07:47 AM
Desert Don's Avatar
Desert Don
Desert Don is online now
Received 4,631 Likes on 1,644 Posts
With a gooseneck??????
Old 10-07-2014, 10:09 AM
DontUluvFod
Forget the hitch. My truck came from the factory with a sway bar system though.
Old 10-07-2014, 10:19 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
The truck MAY have an anti-sway system, but the trailer may still be too much for it...
all the above with low tire air and poor weight distribution with too much weight off the back of the trailer and not on the hitch...
Old 10-07-2014, 10:35 AM
dougcepress
I am not sure what pin weight is or how to adjust it.
Old 10-07-2014, 10:38 AM
dougcepress
I am pulling a 4 stall horse trailer 28 feet long. Also a 24 foot flatbed used mostly to haul hay.
Old 10-07-2014, 10:39 AM
dougcepress
Tires are about 40% left, and they are at correct pressure.
Old 10-07-2014, 12:53 PM
rjcorazza's Avatar
rjcorazza
Pin weight is the weight exerted on the 5th wheel hitch. Of the total trailer weight, 20% should be on the truck's 5th wheel and the other 80% is on the trailer axles. Low pin weight will cause swaying.
Old 10-07-2014, 01:16 PM
jdadamsjr's Avatar
jdadamsjr
adjust it by moving your load around....
suspect it's too light up front so move some of the load toward the front of the trailer so it pushes the rear of the truck down
also, check your trailer AND tow vehicle tire air pressure and set to the max they can hold...
worst case scenario, the hitch system is not centered...
fordmanva
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
19
03-27-2013 01:14 AM
bgathey
Fifth Wheel & Gooseneck RV Towing
10-06-2011 01:07 PM
017.3ex
12-20-2010 08:20 PM
Budman1962
08-25-2008 09:17 AM
56jimmyno1
10-31-2006 11:32 PM
Quick Reply: 02 F250 swaying back and forth
