1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
non-slip mat for bed to keep cooler in place?
Old 10-06-2014, 09:59 AM
zimm's Avatar
zimm
zimm is offline
I have tonnaeu cover on the way (extang trifecta). The bed is also line-x lined. The problem is my cooler or whatever I put in the bed slides and slams everywhere. Will a rubber mat fix that, or should I stick to cargo straps? Maybe some kind of marine carpet that I cut to shape?
Old 10-06-2014, 11:38 AM
seville009's Avatar
seville009
seville009 is offline
Stick with straps. If not, when you make a sharp turn or sudden stop, the cooler will probably just tip over.
Old 10-06-2014, 02:52 PM
phillips91's Avatar
phillips91
phillips91 is offline
Straps would work best. Carpet doesn't really work because of the slick backing. A rubber welcome mat would work too.
Old 10-06-2014, 09:24 PM
Slowpoke Slim's Avatar
Slowpoke Slim
Slowpoke Slim is offline
I just use a small piece of rope or mule tape tied off to the corner tie downs in my bed. Then whatever I don't want sliding or rolling around gets tied to the corner tie down. If your cooler has handles, just tie off one end of rope, loop through one cooler handle, and back to tiedown for second tie off.
Simple and easy.
Old 10-06-2014, 10:49 PM
Portagee510's Avatar
Portagee510
Portagee510 is offline
Simple and easy.
I use rachet strap seems to work best or front seat is great too
And the wife in the back. That's my favorite.
Old 10-07-2014, 09:50 AM
zimm's Avatar
zimm
zimm is offline
Thanks- I'll keep with the straps.
Old 10-07-2014, 10:03 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Stop taking the corners at 50 mph would help too
Old 10-07-2014, 03:46 PM
Nearly Normal Mike's Avatar
Nearly Normal Mike
Nearly Normal Mike is offline
I have a gen-u-wine FORD rubber bed mat. It works great for things not sliding around as well as protecting the bed. A less expensive aftermarket would do just as well, just be sure is 1/4" or so to ensure it won't blow out when bed is empty.
It is fairly heavy and a bit of a hassle to take out and put in when washing out the bed, but usually do that only after deer season.
Old 10-07-2014, 04:03 PM
phillips91's Avatar
phillips91
It will be here soon and I can't wait . I ran over one with my sd a few months ago. Doing 45, hit it with the passengers side of the front bumper and ran over it. Didn't leave a scratch or dent anywhere. My sister hit one in her mariner a few days ago doing 55 and ripped the bumper, grille, fender, fog light and washer fluid jug off of it. Looking forward to getting one the normal way.
Old 10-07-2014, 07:06 PM
Ferguson65's Avatar
Ferguson65
Ferguson65 is offline
I'd do a rubber mat. I have and have always had them. As pointed out if you drive like a nut stuff can still move. But if you drive normal most stuff won't go anywhere. I've got the rubber mat on top of a spray in liner and feel its the best of both worlds.
Also as mentioned earlier, the one bad thing is that it's an unruly SOB to handle by yourself.
Old 10-07-2014, 07:14 PM
05F250DSL's Avatar
05F250DSL
05F250DSL is offline
You could use the built in slots in the bed. Cut a 2x6 to length across the box drop it in and BAM! Everything stays back. You can also run a piece towards. Or two towards the gate and make compartments. It will cost under ten bucks and can easily be lifted out if you need the full length of the bed.
Old 10-08-2014, 05:29 AM
Pit Crew's Avatar
Pit Crew
Pit Crew is offline
I have been using the same rubber matt since 1988, has been in 6 new trucks. The heavier the object the better it stays in place. Getting the mat in or out is not that big of a deal. I just roll it up and lift out. To put it back in, roll it up, set on tailgate, unroll, done
Old 10-08-2014, 05:34 AM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
I use a cargo bar, or sometimes 2.
Old 10-08-2014, 06:13 AM
jdadamsjr's Avatar
jdadamsjr
My platinum came with the bedliner from ford that is ROUGH.
so I actually bought a heavy rubber mat to cut around the 5ers slider hitch...
but that thing is THICK and I gave up on cutting it
Old 10-08-2014, 12:12 PM
The John's Avatar
The John
The John is offline
I use a rubber mat (even though I have a tonneau and my bed is rhino lined) and it works great to keep things from moving under normal highway use....
Quick Reply: non-slip mat for bed to keep cooler in place?
