I have recently put a six inch drop bracket lift on the rear of my truck. With the drop lift in my springs are now 1.5 inches wider then the spring perches on my diff. Has any one else ever done this
I'm almost thinking they are. The front mounts are wider then rear also. I've emailed sky about it as we'll. I'm trying to decide if it's better to move spring perches or cut and modify front drop bracket
The mounts are 3/4 of an inch wider on each side. Every thing else lined up not to bad. I've looked at the kit installed on their site. Every thing I can see looks the same.
