Auto hubs
on
There is a guide somewhere on here to help free frozen ones up. Some go through that process, others, based on a number of factors just by some manual Warns/MileMarkers and call it quits with all the vacuum stuff.
I had a bad one when I bought mine and it was horrible weather so I needed the 4wd. I didn't have time or a warm place to tinker around so I went the the heavy duty version of the Warns.
So if a guy has two auto hubs in his hand and one turns freely and one does not the one rotate is junk? I'm talking the inner splined area where the shaft engages. I have never have a truck with hubs like this. Let me know what you guys think or tell me it's stupid obvious.
i hear ya. i just know the one time the wife drives it i will forget to lock the hubs and she will be in a snow bank calling and asking why 4x4 wont work.
shes not a bad driver thats just my luck. i found a good used one on CL for 75 bucks and im good.
also i found the leak that caused me to think the axle seals were bad cracked nipple must have done it putting the axle back up cause they were new
My Excursion was a bolt on and go affair. I did have to plug the vacuum lines for the stock ESOF's, not a big deal.
This is good advice. I would have replaced with stock but conditions and time did not permit. I prefer to replace with stock or as near to it as possible for ease and simplicity of repairs in the future.
on
Not only that but the aftermarket ones are shorter and look funny plus you lose the automatic feature. There are plenty of cheap used take-offs around that are fixable if needed also. I proved that once before in here.
I've fixed my auto hubs before. It's not that hard, just clean it. Only thing out of hte ordinary was the snap ring pliers.
Everyone said to get a set of warn hubs and don't look back, but I wanted to retain the auto locking hubs. There are times you're on hte highway, out in the middle of no where, wher eyou don't want to get out and lock your hubs because a 300ft patch in front of you looks nasty.
On the flip side being guaranteed your front axle is engaged after a 1/4 turn of a nice warn hub has its merits too...no?
