Ford F150 One Piece Driveshaft Slip Bump- FIX!
Hey fellas,
Purchased my truck new 12-28-2013. On 7-28-2014 I took my 2013 F-150 Screw to the dealer for transmission clunking. In stop and go rush hour traffic, it clunks between 10 & 30 mph. The dealer applied a transmission Technical service bulletin to the PCM/TCM (Powertrain control module and Transmission control module). I was told its a 'learning' transmission and the clunk would get better... NOT!
Sounds like the 'slip bump' issue would fix my truck as well. Great video and information.
Adios.
Adios.
Crystal
7047.1 Taking it in today.
Fast forward to now:
I took it in. The shop manager was familiar with the problem. I have the one piece drive shaft. The shop manager drove my truck and reproduced the problem right away. The problem was fixed with a PCM/TCM software upgrade.
I was told that the problem was compounded by changing from 20" wheels to 18"wheels. I had the change done previously at their shop and apparently they didn't do the system adjustment when the wheels were changed.
I have a 6 speed with the select shift feature. (Put in M and use +/- button to shift gears). When driving along and slow down to under 10 mph, the trans will stay in 3rd gear. When you accelerate however slight the trans would suddenly drop to 1st and you get a harsh bump.
That's all fixed now.
Slip Bump
Hi Folks,
Took mine in to the dealer last week for this problem,there is not a service bulletin for the 1 piece,my service advisor went for a ride with me and felt it and took care of the problem,he said it was quite dry in the female end of the spline they cleaned it out and Lubed it with the Teflon Grease that it calls for,this goes into the Transfer Case and does not get lubrication from the transfer case,unlike a Automatic Transmission that lubricates the splines any rate problem Gone,I will IM Crystal the infro about it,Thanks All
I've got the same thing I've noticed on mine. 2011 XTR 3.5 4x4. From 1st to 2nd or 10-30 mph it basically jerks forward when making the shift. It's the only time I notice it and is most harsh in stop and go traffic. When I give it gas there's less bump.
Will be lumping this in with next service appointment at the end of the month. I'm not too worried just yet. Stay tuned...
Crystal
53000 on it right now and just got it used recently. I've heard the transmission has a bit of a learning curve to it so I'm not stressing out just yet. I'll keep you updated.
#29
#30
Excellent video! Here's a question, I'm a VERY sensitive driver (unfortunately!) so I feel everything going on. Could I possibly be feeling a little bit of this slippage as I drive down a bumpy highway? I feel "something" that seems characteristic in how Ford F150s drive on the highway. It's not something bad, but I can feel something that's not a vibration. I drive a 2014 XLT, and have felt it in a few other 2014's and in my friends 2013 XLT.
