First Post and Rebuild of oil cooler, Got Leak problems, need help!!
09-30-2014, 08:23 PM
on
09-30-2014, 08:32 PM
Welcome to the site.......
Now a little more information is needed.
year of truck
your location
What work did you just do?
What are the specific issues? Where are the leaks etc...
09-30-2014, 08:38 PM
on
could i have bent the housing? is this common? for newbies.....
09-30-2014, 08:40 PM
on
the leak is from the front at the port area. at the two center bolts
What is leaking? Coolant or oil? Where is it coming from?
09-30-2014, 08:41 PM
Seriously?
At this point it could be the rear diff leaking for all we know. Where is your leak? You can't post a question without providing some basic info.
09-30-2014, 08:42 PM
on
2004 F250 PSD 6.0 late model, changed the egr cooler and the oil cooler. water pump, and radiator
09-30-2014, 08:43 PM
once again where is the leak?
09-30-2014, 08:44 PM
on
lol...sry just getting ragged on by the missis
09-30-2014, 08:45 PM
on
looks like center of oil cooler at two bolts in the center.
09-30-2014, 08:47 PM
on
i removed the intake and it is right below the throttle housing, under the test port area,
09-30-2014, 08:48 PM
on
09-30-2014, 08:51 PM
on
the test port has the brass nut and a plastic cap in the front center of the oil cooler housing
09-30-2014, 08:54 PM
Did you make sure to A) put all the new o-rings in place? B) Torque all fasteners when reassembling?
If the answer is yes....then it is possible the oil cooler lid got cracked.
09-30-2014, 09:32 PM
on
Quote:
Originally Posted by
Restlesswildman
Yes i did the o rings and torque to spec. i did not remove the brass fitting at the test port area. do i need to remove the plastic cap and brass fitting to replace any o rings there?
Thanks for the reply's!!!
If i did crack or bend the housing, can i reuse the new o rings and gaskets if not damaged?
Reason: more questions
