wet carpet, passenger side front
To the original poster, look at your evaporator drain tube where it exits the firewall. Its a short little stub and years ago Ford came out with a service bulletin wherein they installed a 90 deg. elbow/extension to cure exactly the problem you're having. My 05 never had a problem until I installed a 2" leveling kit, and then my wet carpet began to appear.
If yours is wet only when it rains, you probably have a leaking windshield. I seriously doubt the water is migrating UP through those clip holes. Everybody's truck would have the same problem if that were the case. You're finding water down there in the trough because that's where gravity is taking it.
tude
11-06-2005 12:28 PM
Marcel
03-09-2004 08:23 PM
