front shackle is maxxed out on f350 95
Old 09-26-2014, 11:32 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
so my truck came with a lift kit on it like 6 inches, and she rides pretty rough even for a older 1 ton now i put new shocks on it and really helped but then i noticed that my front shackles are maxxed out like there smashed into the frame as is the leafs are too long, are there different shackles out there i can buy or are they straight up too long, and is this whats maken my truck ride so rough
Old 09-27-2014, 06:44 AM
bashby's Avatar
bashby
bashby is offline
Some pictures would be helpful.
Old 09-27-2014, 07:39 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
Agreed, pics would help. Most likely the life has been squeezed of the rubber bushings. The small end of the front shackle that goes up into the frame is, well, small. Ridiculously small.
A common front end upgrade is to use Superduty springs. They are similar in length from the axle to the rear spring bushing, but longer from the axle to the front spring bushing. This is why a reverse shackle kit works well with the SD spring upgrade.
If someone put in SD springs up front without correcting the mounting locations (like with a RSK or other) I think you would definately "max out" the front shackle.
When you post pics, try to get one from the side showing how the wheel/axle is centered front to back in the wheel well.
Old 09-27-2014, 05:11 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
hhmm alrighty, and heres a pic
Old 09-27-2014, 05:12 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
i have a welding shop fyi if theres something i can do to fix it
Old 09-27-2014, 05:19 PM
danr1's Avatar
danr1
danr1 is offline
Yea those are not the right springs, either get the correct springs for it or relocate the frame end of the shackle on both sides.
You have zero suspension nothing at all up front running it like that, can see why you say its a rough ride. The front axle might as well be solid mounted it would make little difference. New shocks probably helped in the rear but up front they ain't doing a thing.
Old 09-27-2014, 06:37 PM
bashby's Avatar
bashby
bashby is offline
You need a reverse shackle kit, or make your own. It is abbreviated RSK on here a lot... Try searching those. I thing springs from a super duty truck is the hot ticket with the RSK.
Old 09-27-2014, 07:42 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
Something is no bueno. This is a more normal angle for the shackle.
Old 09-27-2014, 08:04 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
alright yeah i was pretty sure that thing was given me problems, and will a reverse shackle give me more lift ? cuuuss this thing is plenty big lol,
Old 09-27-2014, 08:10 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
and if it dos what can i do about lowering it like removing leaves ? or maybe re locate it
Old 09-27-2014, 08:39 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Like others side. WRONG SPRINGS
A RSK will give more lift. But by the looks of it you have Superduty lift springs which are 3-3/8 longer than OBS springs. in order for the SD springs to work correctly, you need a RSK for SD springs. PRECISION METAL FAB makes such a kit and it will only give your 2.25" over what you have now
Old 09-27-2014, 10:53 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
alrighty,, hmm yeah i really dont wana lift the truck any more, what if i put that kit thing that everyone was talkn about and remove a few leafs ? or just buy new springs
Old 09-28-2014, 08:22 AM
Diesel_Brad
First you have to sit down and figure out how high you want to be and what size tire you want to run. THAT will ultimately make the decision of what to do for you.
Also a RSK with Superduty Stock springs will give the best ride from leaf springs. RSKs come in sizes from 2.25" to 5"
Old 09-28-2014, 08:52 AM
bashby's Avatar
bashby
bashby is offline
Im curious as to how the rear is lifted. Might be wise to lower the truck to somethinv more useable, unless you want to keep it that high. If someone lifted the fro t like that they probably did some other stuff wrong. If you were to post a few pics of the front and rear suspension and steering youd get the best advice.
Old 09-28-2014, 10:07 AM
ewalt98's Avatar
ewalt98
ewalt98 is offline
What bashby says. If the front is already lifted, you should probably start by removing the lift, or figure out what kind of lift it is. The PMF RSK could probably be installed and lower the front by using the new RSK and removing the current lift parts. Hopefully, the previous owner didn't install blocks up front..
Quick Reply: front shackle is maxxed out on f350 95
