Only one door lock
Old 09-22-2014, 05:41 AM
MLBaranowski's Avatar
MLBaranowski
MLBaranowski is offline
Only one door lock
My '53 only has a door lock on the pass. side. It is a standard truck so wondering if this is normal or if one of the doors might have been a replacement.
Old 09-22-2014, 06:41 AM
Indybeer's Avatar
Indybeer
Indybeer is offline
Deluxe Cabs in 53 and 54 had the driver's side lock. Custom Cabs in 55 and 56 had them.
Idea was you lock door and slide out pax side...keeps you from getting out into traffic on narrow roads/streets.
Old 09-22-2014, 06:42 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Very normal. Henry expected his owners to lock the driver's side door - by pulling the inside door handle up - and then sliding across the seat to safely exit via the passenger door - which could then be locked. Your driver side door should lock. Try it. With the window down, so it's easier to reopen the door.
Old 09-22-2014, 07:25 AM
Okiedokie's Avatar
Okiedokie
Okiedokie is offline
I added the key hole to my drivers door.
Old 09-22-2014, 07:34 AM
MLBaranowski
I have considered that. But wondered how difficult that might be.
Being that I just got the truck figured I would drive it a little while before changing much.
Old 09-22-2014, 07:39 AM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,656 Likes on 1,476 Posts
On 53-56's you lock the doors from the inside by pushing the handle down. Pulling up on the handle opens the door.
Old 09-22-2014, 05:32 PM
AXracer's Avatar
AXracer
AXracer is offline
Second most asked question after what frame will swap.
Old 09-22-2014, 09:39 PM
abe's Avatar
abe
abe is online now
Ha-ha! You are probably right!
Old 09-22-2014, 10:14 PM
thomc's Avatar
thomc
thomc is offline
I've thought about making the hole in my drivers door on my 56. Can someone confirm that the locking mechanism is there? The cylinder just was not installed at the factory?
Old 09-22-2014, 11:24 PM
AXracer's Avatar
AXracer
AXracer is offline
The latch is the same. You need the cylinder with spring and lock lever and the cylinder retainer that installs from the edge of the door. Mid Fifty sells a cylinder installation kit with instructions and drill template.
Old 09-23-2014, 10:03 AM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is online now
Phantom of the Phorum
The driver's door even has the slot the cylinder retainer clip slides through, just not the hole for the cylinder.
Old 09-23-2014, 11:42 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
And the plastic plug in the transmission oil pan the
first time the pan is removed.
Old 09-23-2014, 03:24 PM
53FOPAR's Avatar
53FOPAR
53FOPAR is offline
I have a set of door locks and ignition cylinder all keyed the same. Also have the Mid-Fifty's template somewhere. PM me if your interested.
Old 09-23-2014, 06:14 PM
oscajo's Avatar
oscajo
oscajo is offline
Does it work on a 52 F1?
Old 09-24-2014, 09:13 AM
AXracer's Avatar
AXracer
AXracer is offline
I don't know, I suspect not, 48-52 use a completely different type latch from 53-56, but I do know where you could find out, call Classic Haulers Home - Classic Haulers F-1 Parts and ask. They list a door lock with flapper and keys for the 48-52. Ask them to send you one of their free catalogs while you have them on the phone.
Quick Reply: Only one door lock
