WC Motorsports and death wobble
Unless somebody can tell me why I shouldn't, I'm about to buy one of their death wobble repair kits. The truck spent the day at the shop today and the ball joint on the track bar is trashed. I showed my mechanic the WC Motorsports website and he felt that it would replace what I needed and eliminate the problem for the future. I know it's expensive, but I plan to continue driving the truck and think this will save money in the long run. Thoughts?
I have a couple of thoughts on this. One is that the ball joint lasted 11 years and it's the rubber bushing that usually causes a wobble issue anyway. so I wouldn't leap to diss the stock solution. The second is that I use rod ends all the time on my race cars. I would expect to be replacing the rod ends on that WC Motorsports bar on an annual basis, if you drive it much and if you drive it in winter at all. Rod ends just suck in a snowy salty road condition as fas as long life is concerned. I had a small wobble under braking, and a new stock bar was easy to install, I re-used the existing ball joint and the only reason I changed it was the rubber bushing was getting old.
Just that I don`t particularly like rod ends in street suspension, it`s just my opinion. Rod ends all look about exactly the same but they come in dozens of ratings, specifications, teflon lines, mil-spec, aircraft spec, stainless steel, high carbon steel, you name it. The load on these is pretty high, but is in tension and compression, not in bending. You can get boots for them to protect the *****, or make them out of bicycle inner tubes. Make sure to get the torque right on the frame mount side, it has to be 400 ft lbs (actually 403 or some number like that, translated from the metric...). An air impact wrench won`t get it reliably, you need to find a torque wrench. I have a 700 ft lb torque wrench for the wheel nuts on my bus. You can torque that bolt with the wheels on the ground, just steer the drivers side tire out and have a very short extension and you can get the socket on the nut with the torque wrench going in past the front of the tire.
Brian
Brian
Brian
Brian
I had the Ready-Lift version and I think it is the same price as WC. Icon also has one maybe cheaper and BD Diesel has one too that is about half price as the others. Shop around. Personally I would not waste my money on it but would rather replace the worn out ends which I think Ford has a separate part number for now.
Well that ain't happening. So, the bottom line seems to be that any of these options will fix it, as long as the problem doesn't turn out to really be something else like a bad wheel. The reason I don't like going back with the stock set up is that it's likely to happen again. What I need to know is whether these other solutions will really prevent this from recurring.
Kozo
04-05-2013 06:41 PM
bumparker
1997-2006 Expedition & Navigator
04-18-2012 10:20 PM
kengarchow
1999 to 2016 Super Duty
04-04-2008 08:28 AM
Rad76f100
11-24-2004 08:12 PM
