radiator swap?
The question becomes, are you flushing the system?
https://www.ford-trucks.com/forums/9...nge-101-a.html
That should give you a complete understanding.
You want to end up with a 50/50 mix for most locations including Texas. If you see very low temps in winter (artic) you may want to go a bit stronger. Most bottles have a chart or other general recommendations for a proper mix.
Total cooling system capacity including the degas bottle is 27.5 qts. If you drain the radiator by the lower hose or the draincock you'll remove 1/2 the system capacity--about 14 qts. Therefore it takes 14 qts of 100% coolant added back to the system to get a 50/50 mix if you do a complete flush and fill because your starting with water in the system you'll need the concentrate to end up with a proper mix.
If you drain and refill with no flushing,what's left in the engine is 50/50 so you have to account for that.
69slow
03-21-2003 07:03 AM
wosborn
01-22-2002 08:18 AM
