Diagnosis help after injector install
Old 09-28-2014, 08:43 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Have you done a compression test?
  #32
Old 09-28-2014, 08:45 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
So you are still getting the cyl 8 contribution fault after getting the chip updated ?
Stupid question but just want to make sure.
Did you clear the codes and recheck?
How many miles have u driven it since the injector swap?
  #33
Old 09-28-2014, 08:59 PM
rlozer's Avatar
rlozer
rlozer is offline
No compression test done.
I am still getting the #8 contribution fault after the chip came back yes. I have deleted the fault. About 250-300 miles, I haven't been driving it much. I don't like driving the way it is. I'm probably being overly cautious but I don't like things that aren't 100%. Looks like I'll be borrowing a truck for this coming weekend. I need to tow my Jeep to a rock crawling competition, and I don't trust towing with it. Again probably being overly cautious.
  #34
Old 09-28-2014, 09:09 PM
white Buffalo
Well, after 250-300 miles the air should be worked out if the system.. I just wanted to ask again to make sure.
And your still getting the damn code. Sounds like a sound plan.
Better to have peace of mind while towing instead of stressing out at ever engine noise during the trip.
  #35
Old 09-28-2014, 09:13 PM
white Buffalo
Forgot to ask ,
What is your fuel pulse width now with the new tunes?
  #36
Old 09-28-2014, 09:28 PM
rlozer's Avatar
rlozer
rlozer is offline
Yup still getting the code. More than just the code is the way it idles and hesitates pulling out. I don't really think Jody made a change to the pulse width. He didn't see it necessary. The only thing changed was throttle sensitivity. Pulse width is just over 2 milliseconds at idle.
  #37
Old 09-28-2014, 09:33 PM
white Buffalo
Wasn't the FIPW jumping around alot in some of your first readings? .9-2.3??
  #38
Old 09-28-2014, 09:49 PM
rlozer's Avatar
rlozer
rlozer is offline
I'm sorry your right the pulse width was all over the place. Too many datalogs I was mixing them up. The only thing Jody said looked off was the fact I needed more throttle input to maintain speed with the chip compared to with it pulled out. I will recheck the pulse width again.
  #39
Old 09-29-2014, 06:06 AM
Tugly's Avatar
Tugly
Tugly is offline
I suspect sticks, but I couldn't find a trouble code after my speed-reading session. Have you done a KOER? The truck will sound like it's freaking out - so I suggest the "stock" tune during the test.
  #40
Old 09-29-2014, 06:43 AM
white Buffalo
I'm messing up also, I meant key on engine running KOEO test in post #29
  #41
Old 09-29-2014, 08:04 AM
Tugly's Avatar
Tugly
Tugly is offline
To clarify:
KOEO = Key On Engine Off
KOER = Key On Engine Running
  #42
Old 09-29-2014, 05:50 PM
white Buffalo
And just some more info for camparison:
They way I learned it 10 years ago, On a CCT anything under 4% is fine. It's been a long time since I messed with CCT but if u like I can run them on both my 7.3L's so you can have a comparison.
On my Excursion with new 160/80 injectors from FFD I only have 4 or 5 at zero. The rest have some percent under 3 or so. Now having said that, if I change programs to one with a tad higher idle, more go towards zero. If I change it to a high idle program - they all go to zero.
On my F-250 with 8 year old Remans I see #4 with readings around 3-4%, #8 occasionally goes higher than that. It's been that way for a long time.
  #43
Old 09-30-2014, 11:07 AM
rlozer's Avatar
rlozer
rlozer is offline
WB: Thanks for the reference numbers. We will see what if any change the other chip has on things when it gets here.
  #44
Old 10-17-2014, 02:45 PM
rlozer's Avatar
rlozer
rlozer is offline
Ok, It has been a while. The chip FFD sent me to try made no difference in the idle, or hesitation. It did quite down the injectors a fair amount though. I have spoken with Ryan at FFD(a 40min phone call). Turns my local dealer was not getting him all the info I was giving them about what all I have done to diag. the issues. He was very helpful and took the time to come up with a solution with me. I do feel it is just the #8 injector causing the problems, but I wanted new ones for peace of mind. So I am sending the remans back and getting the %30 nozzles swapped over to a set of new AC's. At a cost to me of course, but a fair price IMO.
After the new injectors are in, then it's time for some more tuning changes. There are some things I would like changed, especially after going through this process and learning a lot. I feel some of the noise difference between tunes is injection timing. The ICP and pulse width is very similar with both tunes, and stock. I can't see injection timing data with what I have. Also Jody told me there is no change in tuning for stage one(160cc/stock nozzles), and stage 1.5(160cc/%30 nozzles) This seems odd to me, and Ryan at FFD suggested the nozzle change should be accounted of in tuning.
  #45
Old 11-04-2014, 12:30 PM
rlozer's Avatar
rlozer
rlozer is offline
Ok, new injectors are in. The shake at idle, and hesitation are gone. Thanks to everyone that had suggestions and helped me out.
Quick Reply: Diagnosis help after injector install
