Maybe injectors.
Maybe injectors.
Well it first started yesterday morning, when I left to go to work not even a mile down the road going up a hill I lost all my power and it ran really rough so I shut it off got out and looked for leaks couldn't see any thing more than the slight fuel leak that I had in the valley for a while. I tried to restart it but it didn't start right at first but then it did start but it ran really rough like it was only running on a few cylinders but when I pumped the gas pedal a few times it smoothed out and ran really close to normal. I few times later it seemed like it missed a little bit but nothing major. Then on the way home it started to miss again some and I noticed that it smoked white smoke when it wasn't running right. Some times it would go so low it would shut off then other times it would run normal. Finally I pulled off and checked things out still nothing major until I cheked the oil. There was no oil on the dip stick I put around a quart in and still nothing on the dip stick. So then I put an other gallon and a half in and tried starting it. It didn't start real easy but soon after I started it smoothed out. I ran if on home then and ran it some today and it seems like I am loosing oil fairly fast. It doesn't smoke except for when I start it in the morning. I checked the water in it looks good and I'm not loosing water. Any ideas and opinions would be great. Any questions I will try to answer them.
Nathan7.3
45
03-17-2018 09:13 AM
Eddie C
02-28-2016 04:00 PM
BadDogKuzz
17
03-14-2013 05:44 AM
