Body Bushings? Cant find them?
Old 09-10-2014, 10:20 AM
Royson12's Avatar
Royson12
Royson12 is offline
I have a 1995 F350 4x4 4 door, and a 1995 f350 dually extended cab. Both need cab bushings. All the bushings I find say they are not compatible with the diesels? Seems like they would all be the same to me. Body doesn't support the engine, frame does. Can I just order bushings for a gas truck and they will work? Anybody had any experience with this?
Old 09-10-2014, 11:16 AM
Royson12's Avatar
Royson12
Royson12 is offline
Problem solved. I finally got ahold of a suspension shop, what I should have done in the first place.
Old 09-10-2014, 04:14 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Just incase anyone else runs into this problem....
There is NO DIFFERENCE between a gas and diesel truck body bushings
Old 09-10-2014, 06:12 PM
Royson12's Avatar
Royson12
Royson12 is offline
Why do they do that? It doesn't make any sense! LOL
Old 09-10-2014, 08:14 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
It's a certainly a scratcher...
Keep us updated with your progress!
Old 09-10-2014, 09:59 PM
fordpride's Avatar
fordpride
fordpride is offline
Why when you go get a fuel filter they ask 2wd or 4wd ?
It's a mystery. Lol
Old 09-11-2014, 04:53 AM
Diesel_Brad
Body LIFTS need to be modified to work in a diesel
Old 09-21-2014, 08:44 PM
Royson12's Avatar
Royson12
Royson12 is offline
Body bushings are a pain! Cant get the factories out! Any suggestions? Help? Please?
Old 09-21-2014, 08:58 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Back the bolts almost all the way out, but leave them in the body mount, then hit the bolt head with a big hammer. Might wanna spray some parts blaster of something down in them and let then soak a while first.
Old 09-21-2014, 09:13 PM
Royson12's Avatar
Royson12
Royson12 is offline
Ha! Thanks! Makes sense
Old 09-21-2014, 11:07 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
If they still don't move, this is the method I used. Loop a chain using the bolt you took out the top of the mount thru the links of the chain and into the body mount from below. Put the other side of the looped chain under a floor jack. Then jack up under the frame, if you have the length of the chain tight, as you jack up on the frame it will pull the body mount out with a bang! Clear as mud, right?
Old 09-22-2014, 04:48 AM
Diesel_Brad
Beating on them is almost futile. You will lose most of the shock from hitting it by the by banging it against the RUBBER bushing(think trying to knock a rusty bolt loose hitting it with a rubber mallet)
Make a puller
3" exhaust tubing
7/16 threaded rod and a flat plate of steel
Old 09-22-2014, 07:32 AM
Royson12's Avatar
Royson12
Royson12 is offline
Make a puller
3" exhaust tubing
Is that piece at the top of your puller, all there is of the bottom part of the bushing anyway? Reason I'm asking, I'm thinking on getting the sawzall after them. Right under the top metal washer that is bonded to the bushing.
Old 09-22-2014, 05:52 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
Mine didn't come out anyway I tried until I was able to get my sawzall in there.
Old 09-22-2014, 07:39 PM
Diesel_Brad
That is the lower bushing in the top of my puller(after pulling it free). You don't want to cut the inner sleeve from the "washer". The top and bottom sleeves slide together for a reason
Quick Reply: Body Bushings? Cant find them?
