Vintage license plate paint suggestions
Old 09-09-2014, 06:50 PM
abeagle's Avatar
abeagle
abeagle is offline
I was looking at refurbishing a set of vintage license plates for our 1955 F100 to meet DMV approval for use. They are Virginia plates which are white with black letters for that year. I have cleaned the majority of rust (not all came off) except one plate where the white is worn off. What suggestions do you have on type of paint, matching color of white (black is fairly straight forward), procedures (spray white with black masked then brush black - brush both? primer needed?), other thoughts? Thanks for any input.
Bruce
Old 09-09-2014, 07:30 PM
carnut122's Avatar
carnut122
carnut122 is offline
I ended up spraying the plate orange/red(number/letter color). I then masked off the letters/numbers. I used an Exacto knife to trim masking tape along edges. I then sprayed on the background color (black). there was a raised border around the edge and smaller print that had to be addressed in orange/red with a brush. After the masking tape was pulled, there was still a bit of touch-up needed. I clear coated the entire plate to prevent rust where I might have cut through the paint with the knife. I think I had about 20 hours in on one plate before I was satisfied with the look.
Old 09-09-2014, 07:53 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,451 Likes on 1,398 Posts
As Carnut noted, license plates are a lot more work than they look to make nice. I've always done them just like any other bodywork; straighten, strip, filler, prime and paint. Automotive acrylic urethane or enamel works fine. Hand paint or mask and spray the characters. Match the colors as necessary.
Old 09-10-2014, 02:45 PM
abeagle's Avatar
abeagle
abeagle is offline
Does sound like much more time than I expected. The numbers should be fairly straightforward, but the small scale 1955, Virginia, sounds like some real detail work. Did you guys match the background colors or numbers to an old plate or just try to come close? I think the off-white background may be a little difficult.
Bruce
Old 09-10-2014, 07:12 PM
firstrider's Avatar
firstrider
firstrider is offline
About 10 hrs. in this plate . Am working on another . 4 hrs. in media blast , straightening , priming . paint . Painted the orange back ground then taped off the back ground around every thing else & shot the black .Very time consuming w/ patience .
Old 09-10-2014, 07:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
There's stuff used in the arts called "liquid paint mask" that seems like the way to do it for painting scripts on tailgates and such. I haven't tried it yet, but will need it soon.
Amazon.com: Parma Faskolor Liquid Paint Mask, 16oz: Toys & Games Amazon.com: Parma Faskolor Liquid Paint Mask, 16oz: Toys & Games
I believe there is a Youtube video of using it.
Hasn't anyone on here been in prison to learn how they print plates by the thousands??
Old 09-10-2014, 07:51 PM
carnut122's Avatar
carnut122
Bruce
Mine was supposed to have orange letters the shade of the Wisconsin plate pictured above. But, my truck is red, so I pushed shade into and orange-red category. I figure any cop who pulls me over was nothing more than a sparkle in his parents' eyes back in 1953, and thus will have no idea of the degree of orangeness.
Old 09-10-2014, 09:11 PM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is online now
Phantom of the Phorum
I saw it on one of the "How It's Made" or some show. It's an ink roller type thing.
Old 09-10-2014, 09:16 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
You did a beautiful job on that Virginia paint. Amazing attention to detail. The hours consumed were well worth it.
Old 09-11-2014, 12:15 AM
TxF100's Avatar
TxF100
TxF100 is offline
Yes they used a machine similar to this one:
I was thinking you could do it by hand using a printmakers roller.
Old 09-11-2014, 12:35 AM
52 Merc's Avatar
52 Merc
I tried that on the plate for my Merc, using the same reasoning. It didn't work out quite as planned. The edges just wouldn't come out crisp. Or maybe it was just operator error. I figure I'll have to either tape off the characters and paint, or step up and take it to a pinstriper/letterer and have it finished. I don't have the talent and steadiness to hand paint it. I've tried.
Old 09-11-2014, 09:01 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Like Wayne, I got a set of rubber rollers at a garage sale for a buck, from a lady who was into "stamping". I tried them on an old license plate with Rustoleum. Turned out terrible. I need to find something to avoid hand-trimming this plate, just far too many edges.
Old 09-11-2014, 10:27 AM
EffieTrucker
Has anyone tried the paint markers? It's like a marker, but it has paint instead of ink.
Old 09-11-2014, 11:45 AM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
I don't know if this would work on a plate, but to paint the FORD block letters on the back of my 1970 F350 flatbed I took a foam brush and cut it to the width of my letters and dipped it in paint and tried to cover the letter in one stoke. It worked much like a magic marker, probably like the aforementioned paint markers.
Old 09-11-2014, 12:20 PM
TxF100's Avatar
TxF100
TxF100 is offline
I wonder if a foam roller may work better, kind-of the best of the roller and the foam brush idea.
Quick Reply: Vintage license plate paint suggestions
