96/94/93/89 f350 idi swap
hey yall,
was hoping you guys could help me again. i have a 96 f350 cclb that i swapped out a shot 351w for a 89 7.3 idi engine and a 93 e4od. Ive got it running by jumping power at the soleniod and putting 12v at the fss on the pump, but i cant get any of my electrical to work. I swapped out the 96 dash to a 93 diesel dash, with all the wiring, and changed the engine wiring over to a 94 idi engine wiring. The underhood wiring is from a turbo idi but mine isnt turbo. I was under the impression it would still work. Is the bulk head connector different? I purchased the evtm manual and it doesnt show enough. Ive got no power at the key,and only the fuel guage goes from full to empty when i cycle the key. My exterior lights are lighting up dim, like it has a bad ground, but the headlight switch is off. ive checked the fusible links by the soleniod. Oh and the truck isnt charging. If u guys can help i would greatly appreciate it.
rnfordahillshick
09-08-2014 12:15 AM
Grumpy Polecat
07-14-2007 10:06 PM
