99 V10 Exhaust Y-pipe
I know I have asked before but I am looking for the Exhaust ypipe for pickups with the stock exhaust. And what is the gain from replacing it with this aftermarket one.. Been awhile since I have seen the info on it..
Also going to replace the heads because I have the NON P.I. heads. Would I better off with the P.I. heads or going with the 3 valve heads? I know there is some mods to be made to change over to the 3 valve but I am sure there are people that know exactly how to proceed with that as well.
I am going to be putting a twin turbo setup next spring. Also, is there a larger mass air flow sensor that I can use that comes on a newer model or strictly the aftermarket one?
Thank you!
B.
Thank you!
B.
v10 Y pipe
99 "Ram Horn"? that is a first I have heard of that. How does one determin a ram horn ypipe? i AM assuming some sort of "curl".
What do you or someone, recommend for an exhaust with the turbos? I am needing a major hp and torque upgrade. Need recommendations..
Thanx
Thanx
MARTYSTOWRIG
01-27-2008 12:35 AM
