my puzzle
my puzzle
Hi, first things first I don't have a scanner for this truck, mine is actron auto scanner plus and it wont retrieve any codes . My question is, do i have buy the gold plated scanner and spend all of the money for it, or can i spend below 200 and take care of most issues that I'm going to run into?
I'm new to diesel so enjoy if you have to but I do enjoy working cars , already learned about turn signal fluid, muffler bearing, and my favorite canooter valve.
problem vehicle 1996 ford super duty 7.3 turbo diesel (rollback/flatbed)
338000+ miles
Running on passenger bank only, unplugged driver side injectors 1 at a time nothing changed.
Driver side also had the glow plug wires melted in the valve cover gasket
new parts installed are as follows all 4 ds injectors all 4 injectors wire set(inside)
valve cover gaskets one ds front harness side pig tale
hpop oil (replaced) and oil change
338000+ miles
Could be the idm. It is the electrical box mounted on the drivers side fender. They tend to get water in them and short out. Try taking it out and shake it, and listen for water. And as for scanners, alot dont speak powerstroke. There are a couple options for around 300. A scan gauge is nice. It can be mounted and can do different test, read codes, and see what the pcm sees, A edge evolution is another, option, if you just want to see codes and a couple gauges your pcm sees. It is a programmer but it is not recomended to use it as that. Another popular one is AE. But a little more in price and you need a laptop. And just so you know, the hpop oil is the same as your engine oil. No need to change them separate.
my puzzle
would you happen to have a link to a certain one or a picture I keep finding ones that say compatible with torque but say no to super duty before 2002
my puzzle
just for a recap below and new changes
338000+ miles
also replaces fuel (lift)pump that runs off of the cam
when idling at 500ish fuel pressure is jumping from 45ish to 70
have had solus on it and has been buzz tested all 8 r working and previous code was the sensor at the bottom of the hpop wasn't getting the right reading
Ok I've been waiting almost a 5 days for a friend to make time for me again have this checked again with the scanner and was wondering if the factory oil gage while idling and revving doesn't change very much and stays on the low side of the letter N on normal .
My question is shouldn't the oil pressure rise when accelerating the engine ?
has fresh oil change rotella 15/40
The truck is running and after warm will idle on it own while missing or as if it as a big cam engine light dose come on right after starting and the truck has now power never made out of the garage for test drive
338000+ miles
The best thing is to get the code. The PCM is telling you there is a problem and usually the cheapest way to fix it is to listen. We could start rambling thing to replace but it's doubtful it will help. The oil pressure gauge is just a switch. When the pressure builds it will just go to a preset point. It's good to see you replaced the uvch and burnt wires.
There are several of us in Ohio. I'm about an hour and a half North of you and we have another member in C-Bus as well, but I don't think he has a scanner. I have Torque and a BT dongle that I got for about $20. It works well for me. Here is a link to the one on Newegg where I bought it for $12.
http://www.newegg.com/Product/Produc...tent-_-text-_-
I also happen to know where you can get a Genisys scanner that will work on your truck for less than $200. PM me if you want more info on either one.
I was looking at those blutooth ones but I thought the ones I was looking at said 97 and up is there a difference between the 96 and the 97
I don't remember which one I was looking at but this one works it would be nice but if there is any one that has a scanner that would be able to stop buy and get moving forward I wont to even order the Bluetooth till tomorrow and I was reading peoples reviews and they said it takes about a week to get it
