Need some help. I just changed the lower ball joints on both sides don't know if that matters. I now notice the 4wd won't engage. When I turn the switch on dash to put in 4wd hi. Nothing happens no lights no click nothing. It's like there is nothing there. When I start it up and runs it check the 4x4 light lights up. Any help would be great it worked perfectly last time I used it. Thinking a fuse or vacuum line.
Fuse #16 has absolutely nothing to do with the 4WD system. Perhaps when you were in there tugging on fuses you got #17 to reestablish an otherwise bad connection.
Apparently it does. I have no idea why though. I asked about it a while ago. Fuse 16 was blown- had 2wd and a4wd only- replaced it and everything was right in the world again. If I remove the fuse I have no 4hi and 4 low.
