1997 lug pattern to 1993?
Old 07-13-2003, 07:11 PM
spencry25's Avatar
spencry25
spencry25 is offline
I just bought some rims and tires from a 1997 F-150 with 16" rims, and they didn't match up to my 1993. I thought all 5 lug fords were the same? What stock set up can I use, and is there any difference between 2WD and 4WD lug patterns? Thanks.
Old 07-13-2003, 10:25 PM
dbeames's Avatar
dbeames
dbeames is offline
I think it was in 97 when they changed the lug pattern. They made it larger. 1997 was the year that Ford changed the
F-series/Bronco pairing to the F-series/Expedition pairing. So they made a lot of changes in that model year. You would have to get wheels prior to 97 to have them fit on your 93.
Old 07-14-2003, 12:53 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Does anybody know the bolt pattern on the 97-up? I know it used to be 5 X 5 1/2".
Jimmy
Old 07-14-2003, 12:21 PM
dbeames's Avatar
dbeames
dbeames is offline
LXMAN1,
Yeah from 1980 to 1996, the bolt pattern for bronco's and F150's was 5x5.5". Then Ford switched combo's to f-series/expedition and the pattern turned into 5x135mm. Why? I have no idea.
Old 07-14-2003, 02:13 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
I was told that the reason they changed was because the new trucks have bigger brakes and they didnt want people trying to install 15" wheels which would hit the brake calipers and because they went to the non-cone wheel nuts with the washers and didnt want people using wheels and nuts that didnt work together.
Old 07-15-2003, 07:41 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Makes sense to me. Thanks guys.
Greg Dini
1999 to 2016 Super Duty
01-16-2010 04:45 PM
jeff1975
15
09-22-2009 12:40 PM
DieselBeast01
08-11-2009 12:08 PM
Turnbury95Ranger
1983 - 2012 Ranger & B-Series
10-31-2006 03:50 AM
peon_rob
02-18-2002 03:26 PM
Quick Reply: 1997 lug pattern to 1993?
