computer codes - fuel pressure
With reference to more computer codes post; addendum - 1 Purchased a fuel pressure gauge that attaches to the fuel rail. Pressure measured at 54 psi. This is higher than manuals indicate (39 to 45psi) Also pressure drops steadily after key is off. 54 to 49 in twenty minutes and to 10psi in three hours. Should be near zero overnight. No sign of external leaks. Could this indicate a faulty injector? How can I test to isolate a bad injector? Fuel pressure regulator is new. addendum- 2 Test of MAP sensor showed 1350 rpm at 0 in Hg and 900 rpm at 20 in Hg. The Haynes manual suggests a reading of 300 rpm at 0 in Hg and 200 rpm at 20 in Hg. Are my high readings significant?
dwdranch
01-21-2017 03:05 PM
Da_Lariat_Chariot
08-01-2016 12:26 PM
fordpride
06-26-2012 10:49 PM
