1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Steering Stabilizer Help
Old 08-31-2014, 02:16 PM
shawplatinum's Avatar
shawplatinum
shawplatinum is offline
Have 2013 F250 w/ReadyLift 2/2.5 level lift on 35" Toyo MT's with one hell of a rough shacking steering wheel. I'm ordering Bilstein 5100 series shocks for the truck but for stabilizers would Bilstein factory replacement be enough or should I also purchase a seperate stabilizer beside the Bilstein factory replacement? Is it either or both?
Old 08-31-2014, 07:13 PM
AAubinoe's Avatar
AAubinoe
AAubinoe is offline
Man if the steering is really bad adding more stabilizers is not going to help you. There only meant to absorb minor steering vibrations.
What exactly do you mean by rough shacking?
Old 08-31-2014, 07:20 PM
shawplatinum
All I have is the factory stabilizer right now. The ride of the truck is somewhat smooth but when I hit bumps or encounter a bumpy road my steering wheel shacks side to side. Others I've talked to installed dual stabilizers and the shacking stopped but i'm afraid to replace factory with one and its not enough and have to make more modifications.
Old 09-01-2014, 07:14 AM
rjcorazza's Avatar
rjcorazza
rjcorazza is offline
Search death wobble here for a lot of suggestions. What fixed my stock F250 was aired up tires to door plate spec, blistein shocks and steering dampener, new trac bar. I destroyed the trac bar trying to get it off, which is really the only reason I had to replace it. Pay close attention to the trac bar bushing on the frame side, which from my reading is the number one contributing factor to violent steering wheel oscillation after a road bump.
Old 09-01-2014, 11:38 AM
joe blow's Avatar
joe blow
joe blow is offline
It sure seems too new to have these issues already. I would look further into the suspension related issues
Old 09-01-2014, 12:18 PM
shawplatinum
I have 9000 miles on it right now. At 7000 miles I put the lift and tires and the issue started then. I just always assumed that the lift and tires caused the shack in the wheel.
Old 09-01-2014, 05:32 PM
redford's Avatar
redford
redford is online now
Received 1,595 Likes on 933 Posts
What tire pressure are you running?
Old 10-21-2014, 05:19 PM
shawplatinum
Sorry for not responding sooner. Work offshore overseas. Got home after reading more about this and went straight to the local shop told them issue. They put it on the lift and found that with the Ready Lift SST 2.5/2" lift I installed the track bar relocater bracket and never tightened anything up like I thought the other local shop had checked and done with it was aligned after. I did replace factory shocks and factory steering dampner with Bilsteins and the ride is back and better than factory.
ddzmann68
02-19-2015 08:45 AM
shawplatinum
6.7L Power Stroke Diesel
09-01-2014 01:02 AM
Sleepies
03-15-2006 08:50 AM
mlc5967
17
01-28-2003 12:43 AM
Quick Reply: Steering Stabilizer Help
