1976 f250 addaleaf front?
hey guys, i wana get rid of the raked look of my highboy, would a add a leaf ( long or short???) actully work? or is it just made to fix sagged springs? i have new springs all the way around...so let me know thanks. and wich works better the long adda leafs or the short? thanks
The add-a leaf (long or short) will probably only get you 1" to 1 1/2" of front lift. What block do you have on the rear, the older HB or maybe swap in a 78/79 rear block to drop the rear a bit? I think there is a height diff in the blocks, but not sure.
I seen your other question about pinion angle, how much lift ("wise) are the new springs.
I read it like yes all new springs and wants to raise the front more, cause he does not like the "rake" front to low look, I guess?
That's why I said install a low boy 3" rear block.
Another thread he talks about a bad front pinion angle, I mean come on it a low pinion axle anyway and you go and lift it, and I think no degree shims were used. Can you even fit that anyway?
Maybe I should just shut up and ride the tail gate and see how it turns out? You agree?
Hows MT these days?
Hows MT these days?
