1956 F250 frame question
Hello there and welcome to the forum. Its nice to see another three quarter tonner out there. As I am aware, the half and three quarter tons have the same width for the frames, but the three quarter tons are longer and have more cross members to account for the longer 8 foot bed. 1956 also had an option of an 8 foot box that I also believe had a similar frame to the three quarter ton. Someone else will chime in if I was incorrect anywhere or had missed something important. The people here are very friendly and knowledgeable and able to answer nearly any question you could ask and even some you didn't think to ask.
Ok. Here goes my third attempt at posting here. Wheelbase is a measure of the center of one wheel axle to the center of the other axle, not hub to hub. This means that there is 8" more in LENGTH between wheels on the F250 plus whatever extra frame is on the back to make up for the rest of the 8 foot box. The frames are not any wider to my knowledge. If your truck truly is a 250 (VIN starts with F25) then it sounds like your truck has been modified to put on the other box. Likely the frame was cut to shorten it and make the box fit on it. Do you have any pictures of the box, and, if so, can you upload some to this site so we can see if the box is homemade and what was done to the frame?
The width is the same just the length is different.
Here is a link to some frame dimensions.
http://www.clubfte.com/users/earl/Re...on Information
53 to 56 had the same frame.
So do you know anything about the addition of front discs? Different rims front to back could be a pain, but only if you need a spare.
Bmann, I think you might be mixing your specs. Wheelbase is the distance between the center of the front wheel to the center of the rear wheel. it has nothing to do with frame width. 53-56 F100 with 6.5' bed had 110" wheelbase, F100, 250, 350 with 8' bed had 118" wheelbase. The 118" WB frame is longer from the rear of the cab to the rear spring mount and behind the rear spring mount to the end of the frame than the 110" WB frame otherwise the frames are the same. A number of people have shortened a 118" frame to match a 110" one to use the shorter bed.
There are 8 lug options for disc brakes on these old trucks. There is a company that makes a conversion kit with 8 lugs, I cant find the name now of course, and there was a guy who did his own disc front conversion for an f250 that looked more robust and just overall better, and cheaper than a drop in kit. Just requires some welding and seemingly pretty basic fabricating. I'm trying to keep the 8 lug wheels on my truck so that's my priority but I have no idea on what your intentions are so just do what you want with it! Its your truck after all!
I have a link saved on my PC. My daughters kicked me off to watch Netflix. I will look it up later. Of course we are going a ways beyond the initial question, but it's good info to know. Even if you don't plan on changing your setup. I don't plan on doing the disc conversion, but it's good to have in your back pocket.
Mid-Fifty catalogs used to show the different spring lengths for those pickups, (still do?), and can be a useful source of info for other things, too. I have no affiliation with Mid-Fifty, for the record.
The chassis is the same, but different, as Ax said, and the F250 bed is 8ft, so the rear overhang is longer than just the 8" WB difference, thus a 6.5 ft bed swap is easier than cutting down the F250 bed.
