4.6 motor differences
Old 08-22-2014, 03:33 PM
Crabby144's Avatar
Crabby144
Crabby144 is offline
I have a 2004 F150 heritage (old style). I bought it off a guy with a bad motor and the truck only has 56,000 miles on it. They guy claimed he couldn't find a motor for it because of it being a "heritage''. has anyone ran into this? what 4.6 can i get to work in this truck? what will need inter changed?
Old 08-22-2014, 03:58 PM
jwsrules's Avatar
jwsrules
jwsrules is offline
Hi should be anything 2004 heritage back to 1999 i beleive they put power improved heads on them.
Old 08-22-2014, 04:09 PM
Crabby144's Avatar
Crabby144
The only thing I see different in the interchange book, 8 bolt flywheel and 6 bolt flywheel. Also a "Romeo".
Old 08-22-2014, 08:49 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
There is a rule about these motors that goes like this; take it out and apart to see what's there before ordering any parts.
There are too many changes over the years and during production runs from different plants that can trip you up..
Basically all you need is a new or rebuilt short block with the right crank bolt pattern to fit your flywheel so the total balance is maintained then put the rest of your parts on it so everything is there as before.
Good luck.
Old 08-22-2014, 09:41 PM
Crabby144's Avatar
Crabby144
Thanks for the responses!
Old 08-23-2014, 08:00 AM
vaper's Avatar
vaper
vaper is offline
Do you know what the problem is with the "bad motor"?
You never know, might not need much to repair.
Old 08-25-2014, 09:00 AM
Crabby144's Avatar
Crabby144
i will have it. They guy never brought with the truck. i am actually curious as to what it wrong with it myself. it only has 53,000 miles on it. so yeah i might be able to fix it.
Old 08-25-2014, 12:21 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Look at the 8th digit of the VIN. '6' = Windsor engine. 'W' = Romeo engine. And for what it's worth, those engines are a dime a dozen. You can source that engine from MANY Ford vehicles of that year, that will fit.
Old 08-26-2014, 09:38 PM
Crabby144's Avatar
Crabby144
that's good news! guy i bought the truck off of said it had to 04 heritage only. i thought id check it out. i just want to be able to go buy a motor and drop it in and done. thanks
Old 08-28-2014, 03:12 PM
Crabby144's Avatar
Crabby144
so i found a 04 new style f150, it's a Romeo just like my 04 old style. what all do i have to change?
Old 08-28-2014, 08:37 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
I didn't understand the question. Do you mean you found a donor engine, as in one from an '04 NEW (at the time) body style F-150? If yes, then just strip it down to the long block, and bolt on everything that is specific to your '04 and you're good to go.
Old 08-29-2014, 11:52 AM
Crabby144's Avatar
Crabby144
I just found an 03 Windsor motor. Will that work? I know they are diff. I don't want to buy it and it won't work
Old 08-29-2014, 12:48 PM
Crabby144's Avatar
Crabby144
Sorry about that. I thought the truck I was going to look at was a new body style with a 4.6 ended up being an 03 with a Windsor. Good sounding motor. I'll have everything to drop in mine.
bigwill1767
1997 - 2003 F150
01-12-2017 04:18 PM
rbig1
1997 - 2003 F150
10-09-2016 11:43 PM
dschr
Modular V8 (4.6L, 5.4L)
05-07-2009 08:34 AM
shanes66charger
1997 - 2003 F150
03-20-2009 11:58 PM
cdrtrider
03-03-2003 12:33 AM
Quick Reply: 4.6 motor differences
