Help with ignition wiring!!!
I cannot get spark from my 1979 F-350.
Here is my setup per the moment...
12v from RUN to Ballast Resistor to positive post on coil.
Ballast Resistor to positive (Purple wire) on distributor.
From negative post on coil to Orange wire on distributor.
Distributor is grounded.
This is exactly the setup I hooked up.
I can provide any pictures or information needed otherwise. I am getting over 12V (13.3 to be exact) at the coil, from both the positive and the negative posts. However I am not getting any spark at the distributor.
ANY HELP WOULD BE MUCH APPRECIATED!
Otherwise im not sure if there was an ignition module as well as the msd box. i thought that took its place?
The MSD box was your ignition module. You can't bypass it.
The pickup coil in the bottom of the distributor acts as a Hall effect sensor and sends a very low-voltage timing signal to the ignition module. Transistors in the ignition module then route power to the coil to charge and discharge it at the right time. The way you've got it wired up, you'll be lucky if you haven't already burned up the coil and/or distributor pickup. Neither is intended to have 12V supplied to it constantly; the pickup isn't ever intended to have any power supplied to it at all.
You need to add an ignition module in order for the system to function. A Motorcraft Duraspark II module would be my choice, but you definitely need something.
So i hooked up the wiring as best I could and put the msd box back in the truck. however still no life.
So what suggestions do you have? should I buy an ignition module and or distributor? Or is there a better way to go about this? I was considering an HEI distributor. Would this be easier to hook up, simpler?
Yes, that ignition module should work with a Duraspark distributor, wired as shown.
On the ignition switch, see the S & R? Those stand for Start & Run. So yes, the wire you call out is hot in Run. And yes, the hookup from the start position to the positive side of the coil is necessary. Without it, you wouldn't get any spark when cranking.
