potential rust point
here is what i found for a rust point that i bet we all could run into since the only thing covering the factory hole is foam. it is in the rear of the truck on each side. figured the rust belt guys like me would like to know about this mainly as well as all X owners
I cleaned the area and welded it shut painted top and bottom
i ended up finding lots of "bubbles" all over the rear floor and cleaned and painted the entire area. the main floor was very nice only a few spots the worst there was in the drivers kick panel area
You wont believe all the fun things you will find to weld once you get one and with time the skill will come although I haven't mastered mine yet..
Once you learn what thickness needs what heat setting and your "wiggle" with the gun you can pick it up pretty quick. I am by no means saying it is a easy skill to master nor am I a pro but the tongue I welded on my trailer hasn't fell off yet.
Those cheap 110v welders are good as long as you realize that they aren't meant to weld anything more than maybe 1/8 thick.
Also you really don't need "skill" to just spread some metal on there to fill the gap...
And even if you're incredibly bad at welding you can just buy a grinder and no one will ever know...
Make sure you clean it up well and give it a good coat of paint... a bare weld will rust quickly in the salty areas...
That would do it too. I just figured I would see how it went welding that area and planned on kicking myself for doing it when I burned a hole the size of a quarter.
Something is better than foam tho it was a dizam wet sponge when I pulled it off
