1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F-250 coil springs stiffness difference
Old 08-24-2014, 09:41 AM
Grosjo's Avatar
Grosjo
Grosjo is offline
Hello to all
I want to know how much of a difference there should be in stiffness from a 6.2 gasser camper package front coil springs and a 6.7 standard coil springs.
This question is that I am still looking at putting a Rancho RS6525b 2.5" kit but the recommended RS800118 gasser springs are no longer available.But the diesel ones are no problem to get.
Jo
Old 08-26-2014, 11:15 PM
skanj0's Avatar
skanj0
skanj0 is offline
Originally Posted by Grosjo
Hello to all
Jo
Yes, the coil rates selected for gas motor trucks are generally 2 levels lower than with a Diesel engine. With the kit you mention, it would be a little stiffer with a gas motor. Personally I think these trucks are under sprung anyway, so I would go ahead with it.
Old 08-27-2014, 01:24 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I'm confused. Why cant you just get a kit that matches what your truck already has?
Old 08-27-2014, 06:30 AM
MC5C's Avatar
MC5C
MC5C is offline
Here is the note from the body builders guide:
NOTE: The standard front spring/GAWR on Pickup models is computer-selected based on the total front weight of options ordered. Front spring/GAWR upgrades
are in increments of 150 lbs. on 4x2 models with spring ratings from 3650 lbs. to 4850 lbs. and in increments of 400 lbs. on 4x4 models with spring
ratings from 4000 lbs. to 6000 lbs. Certain option packages include the following front spring/GAWR upgrades: Heavy Service Suspension Package and
Heavy Service Package For Pickup Box Delete — Front springs/GAWR will be selected 1 upgrade higher than standard computer selection; Camper Package
— Front springs/GAWR will be selected 2 upgrades higher than standard computer selection on 4x2 models and 1 upgrade higher than standard computer
selection on 4x4 models; Snowplow Package — Front springs/GAWR is assigned or specifically selected as shown in the chart above. Front spring/GAWR
upgrade is not included if the maximum front spring has been computer-selected as a consequence of options ordered.
The guide is available here; http://api.viglink.com/api/click?for...bodybuild.html
You download the PDF file for the F series Superduty, and the spring rates are on page two. There are at least 15 different springs available. I'm going to guess that your aftermarket supplier ignores that and sells a single spring rate for everything.
Brian
Old 08-27-2014, 08:10 AM
Grosjo's Avatar
Grosjo
Grosjo is offline
No gasser springs available
Rancho is no longer offering coil spring for 6.2 gas Super Duty.At least from what I understood.
Thanks for all the replies.
Jo
Old 08-27-2014, 02:01 PM
BossGasser's Avatar
BossGasser
BossGasser is offline
Go elsewhere. Screw them.
Order parts from a local shop.
Last time I went to the part shop I met a guy that had a flat fender *****'s like my Dad had.
It was fun!
HI DEF
09-06-2014 12:17 PM
JAE88
6.2L V8
10-27-2013 05:51 AM
The Eddie
01-19-2013 04:41 PM
doom899
09-09-2008 10:37 PM
just-n-time
18
06-07-2008 07:59 PM
Quick Reply: F-250 coil springs stiffness difference
