1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 SD motor swap
Old 08-24-2014, 09:03 PM
Dtaylor85's Avatar
Dtaylor85
Dtaylor85 is offline
F250 SD motor swap
How easy would it be to swap out an 02 5.4l triton for an 05 5.4? Any help is appreciated
Old 08-24-2014, 09:18 PM
AAubinoe's Avatar
AAubinoe
AAubinoe is offline
I would think the 2005 5.4L would have addition wiring required. Maybe you could reinstall your 2002 heads on the 2005 block? Sorry I cant give you any real info, but I am interested about the compatibility of the 2v and 3v 5.4L engines as well.
Old 08-24-2014, 10:06 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Why would you want to? The 05 will have all those fun cam phazer issues to deal with. Also my guess is the trans wont bolt up either if you plan to keep the 4R100..
Old 08-24-2014, 10:40 PM
ken kenmnedy's Avatar
ken kenmnedy
ken kenmnedy is offline
if you do the 05 you will need the ecm and motor harness to start....... the 05 motor is a 3 valve motor
Old 08-25-2014, 06:40 AM
Modularation's Avatar
Modularation
Modularation is offline
If I were going to replace the PCM and engine harness I would go with the V10. It added 3V in '05 but never the VCT system.
Old 08-25-2014, 10:43 AM
Dtaylor85's Avatar
Dtaylor85
My 02 5.4 has a junk bottom end and need to just put a new motor in .. I was wondering what other year motors would be compatible
Old 08-25-2014, 11:28 AM
phillips91's Avatar
phillips91
phillips91 is offline
2000 to 2004 would be your best bet.
Old 08-25-2014, 07:14 PM
3/4ton4X4's Avatar
3/4ton4X4
3/4ton4X4 is offline
have fun pulling the motor i just rebuild mine and it is a TIGHT. throttle body and intake must be removed otherwise there isnt enough room to get the oil pan over the cross member. If you decide to rebuild the motor youve got PM me and ill give you some pointers.
Nmaykdm
1997 - 2003 F150
09-15-2018 11:12 PM
Rick Ammons
07-10-2018 07:30 PM
Lehigh
09-18-2015 02:06 AM
huntnrace
12-03-2012 03:07 PM
wrench11
Engine Swaps
06-04-2010 07:42 PM
Quick Reply: F250 SD motor swap
