Please help me stop pouring diesel all over my pants
Old 08-23-2014, 04:49 PM
Icthus in AK's Avatar
Icthus in AK
Icthus in AK is offline
I'm poor after buying my F250 PSD; I'd love to have an auxiliary tank but don't want to spend $700 and lose 2' of my precious 6.5' bed space. So I have 2 5-gal diesel cans that allow me to spill 4 gal of diesel all over the side of the truck and my pants after I fuel from the can. I checked out 3 local stores and Amazon but only saw crap funnels. Can anyone recommend a good funnel with a flow rate greater than 0.3 gal/hr? I have those stupid CARB-compliant diesel cans (plastic, really) and the nozzles on those suck, too.
Sorry for the rant but I also had to deal with the post office today which reminded me, again, why I use FedEx and UPS. Don't even get me started with that organization...
Old 08-23-2014, 04:52 PM
UGA33's Avatar
UGA33
UGA33 is offline
Why not go with a transfer flow or Titan? Replace the stock tank.
Old 08-23-2014, 04:54 PM
Icthus in AK
UGA33,
This is why: "I'm poor after buying my F250 PSD"
Old 08-23-2014, 05:44 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
this fixes the slow flow spout problem
http://ezpourspout.com/wp/
Old 08-23-2014, 05:56 PM
kper05's Avatar
kper05
kper05 is offline
I use these cans. Your patience will quickly return. The price tag is well worth my sanity. Allow gravity to do the work.
JEGS Performance Products 80223 JEGS Spill-Free Fuel Jug - Free Shipping on All Orders @ JEGS
I have one of those new "earth friendly" cans that leak all over the place that I demoted to storing old fuel for the burn pile after washing my tractor in diesel fuel.
Old 08-23-2014, 08:43 PM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Why use cans ?!?!
can't drive to the fuel stop any more ???
Old 08-24-2014, 01:07 AM
Icthus in AK
Originally Posted by jdadamsjr
Why use cans ?!?!
Some places in Alaska are hundreds of miles from gas stations...
Old 08-24-2014, 08:04 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
If I had to use Gerry cans or the like to get through my days regularly I believe I would just use a hose, siphon, or cheap pump of some kind. Just leave the fuel in the bed and whip out a hose.
Being in a harsh environment I'd also prob work out a gravity feed from a fuel can. Just get out, turn a valve, get back in.
Old 08-24-2014, 08:42 AM
porthole's Avatar
porthole
porthole is offline
Finally a way around venting through the spout.
I started doing one of the "prepper" mods to some of my cans.
Tire valve stems with the core removed and metal caps.
Most plastic cans have a thicker wall in the same location where the vents use to be.
Old 08-24-2014, 09:06 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
same concept.. a little air in the back makes the front flow..
Old 08-24-2014, 05:33 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
Why use cans ?!?!
Not when there's a hurricane bearing down on you. All the stations within 500 miles run out very quickly so I keep 10 gallons at the ready over the summer months.
Old 08-24-2014, 07:25 PM
Leonandlisa's Avatar
Leonandlisa
Leonandlisa is offline
This is what I use for fuel and diesel, with the additional hose it allows you to get it in the tank before you start pouring and they pour out quick as well.
VP Racing Fuels Motorsport Container - Square
Leon
Old 08-24-2014, 09:12 PM
Chad149's Avatar
Chad149
Chad149 is offline
Leon
This is what I have as well. I like them.
I like the valve stem idea, I have some small cans for 2 stroke mix that will be getting that mod.......
Old 08-25-2014, 08:25 AM
porthole's Avatar
porthole
porthole is offline
Do one can first. Some of the cheaper stems fall apart due to the gasoline.
There are several prepper videos doing this, don't recall though if they list brands.
I used a spade bit for a clean hole. And a coat hanger to feed the stem through.
Old 08-25-2014, 01:06 PM
Chad149's Avatar
Chad149
Chad149 is offline
I have a uni-bit (stepped drill bit) that'll make a nice clean hole as well. Have two valve stem brands here, will experiment first. And I like the coat hanger idea as well.
Quick Reply: Please help me stop pouring diesel all over my pants
