different spare tire size
If you have to do it and you have a limited slip you could put the spare on the front and make sure you always have two tires the same size on the limited slip rear.
I could imagine that having two different size tires on the front could lead to interesting handling though, so if you do it, take it easy until you know what you are dealing with.
By the way, if you have a locker or a True Trac you won't wear things out as quickly as you would with a typical clutch-type limited slip (like the factory TracLoc). But I still wouldn't drive far or fast with different size tires on a locked axle.
Ouch
Hmmm. My truck is 4wd and the rear is LS. If I put the small tire on the front so I don't burn up the rear clutches, wouldn't I have the same type of catastrophic spider gear failure on the front that is stated above? Wouldn't the front have spider gears? I'm just getting started 4 wheelin with a truck and need to learn more I guess. Appreciate the help.
Not to mention there is not a chance your gonna get a 37" or anything close to that under there. Even if you did you wouldn't want to try and wrestle that thing out from under there. I just took my 30" spare out this morning and it was a pain, so much so I removed the entire carrier and my new spare will be going in the bed.
Oops my mistake.
I originally posted it was a 95 F150. I meant 95 F250 4wd. Typo. Sorry. From reading the replies maybe I should try for 35" tires instead.
I agree with this completely. Even on the F250.
Some people will tell you that up to 35" tires are OK with the F250s. Those people are not paying for the rapidly deteriorating parts you're going to need in a short time to get the front tires straight up and down every 10k miles. Not to mention the expensive tires that will wear the inside tread insanely fast.
