Mishimoto 200° vs. Ford 192° thermostat
#691
Thanks for the offer, but I gave up trying to figure out why the stat won't work in all housings....but it works 100% of the time in the housing from the Ford RT -1169 kit. (So far anyway)
#692
Measured OEM pin height: (0.504in)
and housing pin hole depth: (0.401in)
Measured Mishimoto pin height: (0.584in)
and there's the gap after install.
Now I didn't boil mine, I was playing around with it installed and I "lightly" pressed down on the area that wasn't seated and it moved and seated. I removed the t-stat and inspected it to make sure I didn't break anything.
I inspected it, found nothing wrong. I measured the pin again and it was shorter: (0.456in)
so I re-installed it and no gap:
Filled the truck with coolant, checked it while running, topped it off again and went for a drive. Freeway temps climbed to 200-202* (t-stat opened) and then dropped to 197-199* and then stayed at 200* the rest of the drive.
So far I'd say the t-stat works great, a bit of a headache due to it not coming with a housing but it does work.
#693
I understand,,, just a little gunshy since there is almost 700 posts on how to install a thermostat. Lol.
The housing issue,,, kinda like buying a new truck,, and needing to bring your own oil (it'd be different if the tstat was a "drop in" like most others). Lol.
Don't get me wrong,, I'm definately game. It just seems like you all are doing the manufacturer's job here,,,, and you guys paid to do it. The concept is GREAT!!! Implementation,,,,, needs a lil help.
#694
I installed mine yesterday and here are my findings: New Ford OEM t-stat and housing as of March of last year, coolant temps barely reached 183* in December (OEM t-stat lasted est. 8 months).
At least that was what prevented the Mishi from seating correctly when I mocked it up in a spare C92 I had.
Josh
#695
It's a Ford thing I guess....I think all other vehicle t stats come with the cage built into it, whereas ours uses the housing as the cage. (The 6.4 is the same way)
I'm sure when Mishimoto did the R&D on this thing, they used a new housing vs. finding a used one somewhere...and didn't realize the stat wouldn't be compatible with all housings.
Sure, they could've offered it installed in a new housing if they knew then what they know now ...but then the price would probably be close to $100.
Like alot of new products, there are issues in the beginning until things are figured out. This one has been figured out by installing it in a new housing, it will definitely work....any other housing is a gamble.
#698
I imagine once the buying frenzy is over, and maybe another manufacturer begins offering something similar installed in a housing, the price will go down. (Remember the price of flatscreen tv's a few years ago?)
#699
#700
Gonna get a fresh housing this week...
Rory
#701
Drove mine again yesterday after changing it our from stock a few weeks ago. ON the test run it got up to 202-207 and pretty much stayed in that range. Yesterday it just kept climbing! I got it home before it got no more than 212 coolant and 225 oil. I gotta wait until outdoor temps moderate so I can look at it. I don't know what blew but there was steam all over the place. Could it have been that thin "O" ring they are sending out with the new 'stats?
I don't think was a "thermostat" problem but a failure of a component. Or even an installation error I may have made..... The coolant was leaking out at a pretty good clip and being blown all over the engine compartment by the fan. Yeah, I heart it start to roar once the heat got up there. I didn't attempt to look at the fan speed...I was too busy trying to find a turn-around to high-tail it back home!
I just went out to the truck to check it.... found the heater hose connection either OFF or BROKEN the connection to the heater valve (engine side). Phew - I don't usually believe in coincidences but this time it just HAPPENED to be around the same time I replaced the thermostat. And EASY to get to too. Lucky me. I also get to have a coolant change at the same time.
Guess all I have to do after the repair is 3/12 gallons of GO5 and 3-4 gallons of distilled, right? As all the coolant boiled/blew out this SHOULD suffice?
I bought a Mishimoto and, having read much of this thread, boiled it prior to installing. After boiling, I found that there is still slight clearance between the t-stat plate and housing.
I bored out the pin hole slightly but this had no effect. I boiled again to make sure it had an opportunity to re-seat. Still no improvement.
I can roll the plate around in the housing a little bit, which tells me the pin isn't against a side wall in the housing bore, so I know there's enough clearance radially.
I'm thinking there is interference where the first shoulder (from the pin end) contacts the boss in the housing. If those two contact before the plate seats it will never really seal, no?
My housing is a 92.
Probably going to dealership to get a new assembly and harvest the oring & housing.
Money-Pit: If you'd like a 92 housing with modified bore which does not fit a Mishimoto, PM me.
Rory
My housing is a 92.
Rory
Thanks
I replaced the housing and within 4 miles my temp hit 200. I did not take the air box out, I used a 1/4" ratchet and a 10mm socket. Ford couldn't have put that fuel line in a more aggravating place.
For some reason the bolts that hold the housing were really hard to put back in. I carefully worked them in and out with anti-seize and I finally got them in and tightened.
I agree, it got outa hand....who would've thunk that would happen installing a thermostat?
Not sure if this thread is good or bad. I read a couple pages and it seemed there is a need for a sticky on the proper install instructions. What I've read of this,,, it seems hit n miss on getting it installed and getting it to function properly,,, on the first shot. No way could I sell it and risk CAUSING a problem. If it came with a housing,, already boiled and seated,, I'd stack them next to the gatorback belts we now stock (which I have to order because nobody carries them).
https://www.ford-trucks.com/forums/1...l#post14885796
Feel free to follow-up with any additional install concerns/questions!
Thanks
#702
I posted this elsewhere too..... If anyone installed the coolant filter kit with the PLASTIC T and hose adapters get rid of them BEFORE you go to the 200* thermostat. The plastic MELTS ! I'd change the t and barbs (plastic) anyway before they fail. I went to brass fitting I got from Home Depot.
#703
Josh
#704
#705
Great question! Our thermostat emulates the design of the factory unit and will fail in a similar fashion.
So you are or are not saying it fails in the open position?
Thanks guys! We have a ton of customers running this particular thermostat with 0 concerns expressed during installation. The actual success rate is far greater than 50%
