Diagnosis ?
Old 08-23-2014, 06:51 AM
cheezit's Avatar
cheezit
cheezit is offline
Mike I have heard the same thing. One of the things I brought up in fact was that.
The issue was related to the other studs iirc m2 or was it h2 I can't remember their name.
Old 08-23-2014, 06:59 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
H11 studs is what I believe you're looking for.
Old 08-23-2014, 07:12 AM
jsm180's Avatar
jsm180
jsm180 is online now
This is great info..
Let me add fomoco updated the process by adding a 3rd 90* yeild. How much is left beyond that?
Do you know when that changed? My 03 manual shows 3 stages. They may have changed the bolt specs also.
Old 08-23-2014, 07:14 AM
cheezit's Avatar
cheezit
cheezit is offline
Tim as always your my hero. Thank you
It was to early to think
Old 08-23-2014, 08:03 AM
BryanStein's Avatar
BryanStein
BryanStein is offline
Matt, just to make sure you understand. The fan clutch can be bad and the fan still spin. When the clutch locks up, the truck will sound like a prop airplane if the coolant is over 220 and the engine is running around 2000 rpm. Yes, it will move that much air. It's unmistakable. The clutch only locks up at higher EOTs or ECTs so it doesn't sound like a prop airplane all the time.
Old 08-23-2014, 05:48 PM
Mattb60's Avatar
Mattb60
Mattb60 is offline
Bryan,
Reps sent for the GREAT info.
Thanks !
Old 08-24-2014, 08:47 PM
Mattb60's Avatar
Mattb60
Mattb60 is offline
This might be material for a separate thread, but does anyone have thoughts on or experience with the BPD adapter that converts to a mechanical fan clutch like on the 7.3 ?
Old 08-24-2014, 08:51 PM
BryanStein's Avatar
BryanStein
Thisisthe first I've heard of it, so I'll be no help there.
Old 08-25-2014, 06:21 AM
jsm180's Avatar
jsm180
It's supposed to be a cure for high oil temps with the BPD external cooler. It's more like putting a bandaid on top of a bandaid in my opinion.
blrman1962
11-23-2017 12:37 PM
maxine
07-21-2015 12:27 AM
DeeJayWoody
05-09-2015 10:37 AM
Duallymade
1999 to 2016 Super Duty
03-24-2014 08:16 PM
egregg57
12-03-2012 10:29 PM
Quick Reply: Diagnosis ?
