Intermittent miss fire
on
I recently had headgaskets go on my diesel, I pulled the olde girl apart, replaced the head gaskets and seals. Got er all reassembled fired it up ran smooth as glass no pushing out coolant or hydrolocking anymore. After about 5 minutes of idling she starts to just randomly missfiring, sometimes for 10 seconds sometimes for a few minutes, it can get bad enough to the point she starts to bang and smoking like crazy, I did do 3 oil changes since the head gaskets in the time of 3 hours, the first two drops the oil came out with a bunch of gray crap that would show if you disturbed the oil. The third time it came out just black. The oil pressure seemed low too me at 14lbs and was still dropping pretty steadly. The only other thing that was wierd when I pulled the oil fill cap I could hear something squeaking. The engine had a bunch of sludge and like other parts of the truck showed since of it had sat outside for a long time before I got it. My return lines are leaking, severly but it should cause it to miss all the time. The truck has 232,000 km on the odometer but the speedo dosnt work. When I had the heads off it looked like it had more around 400,000 on the engine. The truck is orignal ip and injectors.
I would have to say it's injector related. You're either not getting fuel to that cylinder (intermitantly) or you're losing compression. Now you could have a piston ring that's staying compressed at times. Carboned up. I would put a new pump and injectors on it. With 400k I'd say you're due. Again I'd say it's fuel related. If you think your rings are frozen up from all that gunk you got out of your engine. You could try soaking them with something. Pour it into your glow plug holes or injector holes. Trans. fluid, penetrating oil, brake clean. They used to make this stuff called TDC cleaner, but they pulled it off the shelf because it was to caustic.
on
on
Good news did a return line kit clean the miss up runs great till 170 degrees than runs rough again and diesel knocks and smoke. Oil pressure holds steady at 13/14 psi at 900 rpm. Idle has always bein set high on the pump. Whats considered excessive smoke out the cdr and oil fill, I understand a small amount is normal, and should clean up, mine at temp smokes pretty steady at any temp.
4x4countryboy
33
11-13-2022 04:37 PM
1986F150six
08-13-2018 11:31 AM
Izzy3110
1983 - 2012 Ranger & B-Series
08-17-2011 08:33 PM
Wild Karrde
25
03-05-2008 07:41 PM
