Every system is failing - Dealer says PCM
It looks as though I have figured out root cause, I will be taking it back to the dealer this week. Any time the problem happens, I set the emergency brake and then release it. As soon as I release the brake, all of the warnings go away and the truck returns to a normal working state.
Can you please translate this? I'm genuinely interested but my brain cannot connect the dots on that sentence.
Those new trucks are nice....really nice but I will keep my finely running 6.0 thank you!
"Sitting Idle" to me means sitting around not doing anything
"Idling" means sitting there running at an idle not doing anything
#29
Correct, I did not leave the truck idling; I left it idle.
After the last trip to the shop, I had my truck for about three weeks with no issues. Then, It started happening again. I have now ween it 5 times in 2 weeks.
The dealership believes it to be an issue with the cluster and they want to replace the entire thing. I am not sure I believe it but I will be taking it back to them and letting them do their thing
#30
Hi Dbolding!
Looks like we are having the same problem. I started a thread here a while back, 3 tow-ins later, problem still not solved. Truck has been in the shop for just over a week now on round 3:
https://www.ford-trucks.com/forums/1...th-errors.html
My dealership/service center are having a Ford Tech come in and see if he can find the problem.
I'll be updating that thread once they've *hopefully* found the cause. Maybe the solution can be of some use for your team.
