1965 Ford F100. Could use some advice.
Looks to me that the starter had the wrong number of teeth to match the flywheel (there are a lot of starter/flywheel combos out there for this engine family) and bound up when engaged.
~Steve
I don't see how over-torquing one bearing cap could lead to the engine being "too-tight." I would pull the plugs, put a socket on the damper bolt and turn the motor over by hand a couple of times. It should turn smoothly and easily--perhaps you can rule out the whole "too tight" red herring.
~Steve
~Steve
Would you recommend pulling the plugs? Or would it be okay to just pull the wires?
Thanks!!
Chipped flywheel teeth is a common problem.
C5AZ-6384-A .. Flywheel Ring Gear - 184 teeth / Obsolete - Available from autoparts stores.
Applications: 1965/71 FE Passenger Cars & 1965/76 F100/350 352/360/390 all with 3 & 4 M/T
The old gear is sweated off the flywheel, the new gear is sweated on. Any autoparts machine shop can do this.
FE A/T & M/T 3 hole starter is the same: 1965/76 / 1958/64 FE starter has the Bendix gear reduction (aka inertia) type starter drive, 1958/64 FE flywheels have 148 teeth.
For goodness sake, STOP taking the truck to Kwik Trip. Stop trying to polish the turd. Start over.
Buy a crate motor, drop off the original motor for a pro rebuild, or do it yourself. You'll be money ahead. In my experience trying to cheap out always ends up costing more money, not to mention time and aggravation.
Sometimes it works OK, but that's not the way to bet.
FE A/T & M/T 3 hole starter is the same: 1965/76 / 1958/64 FE starter has the Bendix gear reduction type starter drive, 1958/64 FE flywheels have 148 teeth.
A little update: Looks like he is not going to be honoring the free labor thing after I spoke with my father this evening. After the flywheel is fixed, we may buy an engine stand and do it ourselves or just take it to a good shop. We are in the DFW area, so are there any shops anyone recommends? If we do it ourselves, I will just have to borrow a hoist and buy an engine stand. We may end up doing that. Any responses, as always, are appreciated!
#28
This will be ending, trust me.
Looks like he want's you to pay for his blunders. Go see Judge Judy. Doesn't Texas have some sort of Automotive Bureau to take care of crooks like him?
#30
Just want to say I appreciate all the answers. My dad read everything you guys said and slept on it. He already had the flywheel on order, so once the flywheel comes in he told "D" to stick it in the back of the truck and we are getting it away from that shop.
I am still curious if anyone here is in the DFW area or knows of a shop in this area to recommend. Doing the work ourselves is an option, but requires an engine stand and a LOT more time.
