Steering wheel lights out
Old 08-18-2014, 07:59 AM
rickvm's Avatar
rickvm
rickvm is offline
Franklin, hoping you can help me out. my steering wheel lights r out and need to know which wire runs power to those. also the led in my headlight switch is very dim.I checked the wiring and all the wires check out with high 11's and high 12 volts.i checked the volts at the led in the switch and it read 2.18 v.i have another light switch from the salvage yard and the same thing. which wire powers that light. also, the light only comes on when the key is in the on position or back for accessory. if i just turn the lights on it wont lite, only with key in ignition in those positions. truck is a 2000 f350 xlt dually thanks, Rick
Old 08-19-2014, 07:36 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,684 Likes on 1,360 Posts
The steering wheel illumination comes from the same lightblue/red that feeds all the dash lights. There should be a lightblue/red that comes up behind the steering wheel, and there is a sliding contact that several wires go through, so the wheel can turn, but the power can still transfer through. Be careful, the airbag wiring goes through this same contact piece. Usually you will have a airbag fault also if there is a problem with this sliding contact.
Same with the headlight switch. This is where the lightblue/red wire originates from that feeds all the dash illumination. There is a module inside the switch that varies the voltage on this circuit for dimming. As the circuit comes out of the switch on the lightblue/red the light for the headlight switch is tied into this same wire. Looking at the diagrams, there is a ground(black wire) leaving the switch for this circuit. It could be a poor ground causing just that light not to work correctly.
Old 08-20-2014, 07:03 AM
rickvm's Avatar
rickvm
rickvm is offline
Ok, I'll check those wires and the ground and get back to you after work. Really appreciate your quick response. Thanks
Old 08-20-2014, 08:22 AM
rickvm's Avatar
rickvm
rickvm is offline
Just check wires, I'm only getting 11.28 volts on red and blue wire. Other wires are 13.46 volts. Ground seems good but I'll reground it.
Old 08-21-2014, 07:46 PM
rickvm's Avatar
rickvm
rickvm is offline
I rechecked the blue/red trace wire and it's putting out 2 volts less than the other wires. 11.28 with truck on and 10.09 with truck off. The wire going to the steering wheel is the same ,volt wise , but only is hot when ignition is on and the lights don't work and the led in the switch is dim. I'm thinking it's something in the ignition? I had an alarm put in a few years back and maybe they screwed up something somewhere? Also, the bottom brown wire that goes into the plug gets real hot and the plastic is brown instead of white. Thanks
Old 08-21-2014, 08:13 PM
Franklin2's Avatar
Franklin2
11.28 is probably coming from the dimming circuit inside the switch. Turn the dimmer **** or however you adjust the brightness and see what happens. That might be all you get out of it.
Old 08-22-2014, 06:56 AM
rickvm's Avatar
rickvm
rickvm is offline
ok, ill check that. Do those two lights only work with the key turned? Shouldnt they work with the switch? Is that where my wiring is bad?
Old 08-22-2014, 07:15 AM
rickvm's Avatar
rickvm
rickvm is offline
Checked voltage and it does work with the dimmer and thats all the volts its outputing. I just checked my excursion and the switch and steering wheel lights work with the switch and not the ignition. I didnt see anything tied into that wire besides my guages but ill recheck it.
Old 08-22-2014, 08:23 AM
rickvm's Avatar
rickvm
rickvm is offline
What is the black with red/ pink trace wire? That is the wire triggering the led in the switch.
Old 08-22-2014, 08:25 PM
Franklin2's Avatar
Franklin2
They show no black/red or black/pink at the switch in the diagrams. They show the LED for the switch illumination internal to the switch. If you have a little black/red attached to the switch itself, they do not show it, they only show the harness wires coming to and leaving the switch.
Old 08-23-2014, 10:49 AM
rickvm's Avatar
rickvm
rickvm is offline
They're are two black/red wires and they are coming from the harness. I need to figure out how to post a photo on here.
Old 08-23-2014, 11:58 AM
rickvm's Avatar
rickvm
rickvm is offline
the two wires are coming out of the grey plug on top right. also what is the orange wire?
Old 08-23-2014, 01:29 PM
JWA's Avatar
JWA
JWA is offline
Received 1,394 Likes on 1,103 Posts
Part of this problem is that hatchet job someone has done to this wire harness and connector. Besides those Scotch Lok pieces I see several wires crushed and potentially cut inside the insulation.
This needs to be dealt with regardless how it does or does not apply to the SW lamps.
Old 08-23-2014, 04:49 PM
rickvm's Avatar
rickvm
rickvm is offline
I apologize about the hatchet job, I guess too much poking with the light tester. I'll get to that just as soon as I can. So what is that black and red wire?
Old 08-23-2014, 07:33 PM
Franklin2's Avatar
Franklin2
I have looked again. I see them in your picture, but I can't seem to track them down in the diagrams on the DVD.
Quick Reply: Steering wheel lights out
