1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Is my engine going to be forever broken?
Old 08-19-2014, 02:45 PM
Fastfwd's Avatar
Fastfwd
Fastfwd is offline
Bought a used 2011 6.2L with 40k miles. Ran great for a while winter doing mostly short trips. Went to do an oil change at the beginning of summer.
Then on the week I was to go on vacation check engine light. Canadian dealer tells me it won't be covered by 10 year powertrain because I don't have the proof that all oil changes were made.
I get it checked in the USA and they replace solenoid and cam phaser under warranty. 7000 miles later I get the light to change the oil. I'm just a day away from home so I wait until I get back.
At the dealer today for oil change and he tells me I have NO oil left and that coolant and oil are mixed.
Why did I not get any light for low oil?
Let's say it's a seal that failed and they replace it(hopefully warrantied). Will the engine be reliable after that or should I trade that truck ASAP?
Old 08-19-2014, 03:30 PM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
Sure sounds to me like your dealer is giving you the run around in some aspects. Did you check to see if it has oil? I am fairly certain if no oil, the engine would be rattling and a burnt smell on dipstick.
Old 08-19-2014, 04:20 PM
Forddiesel06's Avatar
Forddiesel06
Forddiesel06 is offline
X2 on that.
Old 08-19-2014, 04:28 PM
Fastfwd's Avatar
Fastfwd
Fastfwd is offline
He showed me a dry dipstrick and a sample of oil contaminated coolant. I have no reason to believe that he his lying.
I'm just wondering if you would be comfortable keeping that engine after those 2 issues(cam phaser, coolant/oil mix) or if you would trade the truck for another one?
Old 08-19-2014, 08:27 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
sounds like a head gasket blew, running an engine on oil and coolant cream foam soup probally cut 90% off the life expectancy of all bearings aand bushings to say the least.
Old 08-19-2014, 10:57 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
I thought cam phasers were an over head cam issue and isn't the 6.2 a pushrod motor? Sorry not your problem here but just wondering, also didnt know ford had a 10 year warranty?
Old 08-19-2014, 11:13 PM
nojoke327's Avatar
nojoke327
nojoke327 is offline
6.2 is a ohc motor just like the mod motors.
I would trade in the truck if it is affordable and feasible to do so
Old 08-20-2014, 06:32 AM
Slowpoke Slim's Avatar
Slowpoke Slim
Slowpoke Slim is offline
Depending on how long it ran in that condition, it's probably time to replace the engine. Crank mains and rod journals are probably gone, bearings gone, cam lobes gone, plus all that crap circulating through the oil passages... Engine may be rebuildable if not warranteed, won't really know til you get it pulled apart and inspected.
I would not expect good news honestly.
Old 08-20-2014, 07:41 AM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
Temp fix it if possible, limp to dealer and get rid of that soon to be headache moneypit. Its toast! You will pay more to rebuild than down payment on newer truck.
Old 08-20-2014, 08:48 AM
FordServiceCA's Avatar
FordServiceCA
FordServiceCA is offline
Official Ford Rep
Thanks for reaching out, Fastfwd. I'd like to escalate this to the regional customer service manager for your area for further assistance. Please send me a private message with your full name, dealership information, VIN, and best daytime contact number. I'll be on the lookout for your information.
Brittany
Old 08-20-2014, 08:57 AM
zimm's Avatar
zimm
zimm is offline
Edit- Go with ford service above. But if you are not covered and you like the truck, get a 6.2 from a wrecked 2011 and have it swapped in for a few thousand dollars.
Old 08-20-2014, 10:33 AM
Fastfwd's Avatar
Fastfwd
Fastfwd is offline
I sent a PM to Ford rep Brittany. Hope that helps getting things to run smoothly.
Just to be clear on what happened.
Original check engine was for exhaust cam delay. Mainly and anti-pollution feature. It was fixed under warranty by a Ford dealer in the USA during my trip. I was told there was no ill effect from this apart from higher pollution emissions. They first replaced a solenoid and then a cam phaser. Problem never came back after that. Engine always ran great before, during and after the check engine.
Oil pressure was never low. Oil light never lit up. Never saw any white, black or blue smoke coming out of the exhaust. MPG was exactly what it should be and engine ran great. No spills of any kind under the truck.
Change oil light did come on. I brought the truck to the dealer 300 miles later to get it changed. That's when they showed me a dry dipstick and coolant that was mixed with oil.
As far as I know oil pressure was never low and engine always ran great(sound, MPG, no warning lights) I'm just no expert at engine's internals and wanted expert advice on long term effects of running an engine with low oil and oil in coolant. Maybe it will be fine after they change a gasket or whatever else is needed.
I could trade for an F150 that would be more appropriate to my trailer since I ended up getting a light pull behind instead of a 5th wheel. But I would definitely lose some money on the trade due to sales taxes and salesman profit. Also my current truck is well equipped with bed cover and summer/winter tires which would not fit the F150.
I would prefer to keep the F250 but I don't want it to be unreliable and expensive in the coming years. Thanks for your feedback.
Old 08-20-2014, 11:05 AM
speakerfritz
keep us in the loop in spite of ford service trying to pull you off line. they certainly realize the negative impact bad PR has ......the pressure is on.
Old 08-20-2014, 11:08 AM
speakerfritz
nope....too many wear parts that need oil....if they get this engine back on the road with out a rebuild its not going to be one of the long mile club members.
ford seems to have a lot of problems with these engines....not a rare event at all.
Old 08-20-2014, 01:01 PM
snelldawg's Avatar
snelldawg
snelldawg is offline
Really? I haven't heard of many problems at all with the 6.2/
Quick Reply: Is my engine going to be forever broken?
