V10 vs Diesel for Brush Fire Truck
I vote diesel.
1. Our V10 ambulance is a little lacking in power. It weighs in around 7000lbs and only sees streets. And yes, it is geared properly.
2. Emergency vehicles can apply for EPA exemptions.
http://www.epa.gov/oms/highway-diese.../420f12025.pdf
I vote diesel.
Sean
If your ambulance only weighs 7,000 lbs it's most like an E-series, and those never got the 3V V10. There's quite a difference between the 3V engine they put in the Super Duties after 2005 and the old 2V used in the E-series.
on
I still would go diesel, Those trucks sometimes have to idle for 12 plus hours, we bring fuel tankers in to refuel the trucks while fighting a fire, we dont drive the trucks near the fire, we are a signed an area to hold and we could be there for ever or intill we move or get relieved, I dont know what the v-10 would do when you get that thick black amber lite smoke banking down on you, it happens especially when the fire crowns and your standing underneath it, We jump in the truck or put our scott packs on. I think the gas would stall right when you need to get the heck out of there.
Not to answer for David, but I have heard that argument from several other people before and the line of thinking was always that diesels make their own air since they have a turbo. So even if there was no oxygen the diesel would still run. Either engine requires there to be oxygen in the atmosphere in order to have combustion though, so if the gasser will stall so will the diesel.
on
Put your hand over a running diesel's inlet, sucks your skin off may stumble a bit but it will run, do the same thing to the gas, once you lose vacuum it will stall out, Yea the smoke in the diesel will affect it but when you compare it to the gas, it will take many attempts to clear it, and god forbid it floods your stuck, and you fire guy's know what happens when that fire crowns. they wont identify the body's till it's put out.
on breakdown work without any trouble. You also do not have to worry about cylinder washing in a gas engine.
#29
X2. My truck weighs 13,000 and it has no problems on on grades.
