engine swap
Old 08-16-2014, 01:53 PM
tnvolsfootball's Avatar
tnvolsfootball
tnvolsfootball is offline
engine swap
want to put a1998 4.6 out of a 4x4 f150 in a 2000 4x4 f150 that has a bad 5.4 in it. what do I have to change to make it work. besides the exhaust thanks
Old 08-18-2014, 10:01 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
The ignition is not the same, the harness is not the same, the program in the PCM is not for a 4.6 as far as ignition timing curve as well as the fuel curves.
You have more hassle than just setting the motor in place.
Good luck.
75ford250
Engine Swaps
10-25-2017 04:45 PM
pkconstruction
1997 - 2003 F150
02-18-2013 05:14 PM
medo1
1997 - 2003 F150
10-26-2009 09:32 PM
justynrook
Engine Swaps
04-11-2009 01:50 PM
Quick Reply: engine swap
